Re: vacuum for ROS
Paul Dwight
>I have a year-old ShopVac that's from their new lineup of quieter machines. They still sell the old noisy ones, too, so you have to be careful about which one you're seeing. Mine works very well and it is MUCH quieter than older models. One micron cartridge filters are available. ShopVac also sells filter bags, which I highly recommend, especially for sanding -- otherwise the fine sanding dust will quickly clog the filter.
The ShopVac would be even better if it had an auto-start switch. I bought a $20 switch at Sears that does the same thing, though not quite as elegantly.
When I bought the ShopVac it came with a 2-1/2" hose. For sanding, you'd probably need to buy a smaller hose.
I understand Ridgid also has a new line of quieter vacs, but I have no experience with them. Since you're going to be using this with a sander, I would consider the Ridgid only if they sell filter bags for it -- there's no other efficient way to keep the filter from clogging.
Hope this helps. -- Paul
