jointer
jointer
jointer
Myra in TN
>I'm planning to buy a jointer and would like, of course, the best and most jointer I can get for the least money.
Questions:
1. How much jointer do I need? I am learning to make furniture and don't want equipment that will be a hindrance.
2. What brand of jointer, being sold today, is reliable?
Thanks in advance for the help.
Re: jointer
Re: Big can of worms!!
As large a one as you can afford. Many are content with 6" jointers. Many want larger jointers (8", 10", 12"). I just recently bought an 8" jointer to put in my basement shop. I would have loved to get a larger one - but there was no way I could get it around the house and into the basement! You can make many pieces of furniture utilizing a 6" or 8".
Many brands are reliable - it depends on the dealer and what sort of support you get. I like Steel City - they are the "new kid on the block" and are trying to make an impression.
Re: jointer
Re: jointer
Howard Norman-Prescott, AZ
>I used an old Craftsman 6" jointer for years. It wasn't very good but it was better than nothing. A couple of years ago I bought a Grizzly 8" G0490 jointer. Great improvement.
If you can afford it get a 8" jointer to start with. If you are watching your pennies like most of us I would say look for a used 6" jointer from someone that is upgrading to a larger jointer.
All of the major brands have their admirers and their detractors. When I bought the Grizzly I felt that they had the most bang for the buck at that time. Haven't looked since then.
Howard
Re: jointer
Re: jointer
Bob McGovern
>Myra: A 6" jointer will serve for most furniture shops; with practise, you can joint up to 12" wide stock on one. Anything wider, you are best to rip, joint & reglue anyhow.
I've put prolly a million board feet over my Sunhill (GeeTech) 6" jointer, and built lots of furniture & twenty kitchens. Runs about $400 new. Never given me a bit of trouble, tho the bearings and belt are starting to sound tired. Has a longish bed for a small jointer, and the fence tilts both ways. The Grizzly might be okay, too. (Even the marquee brands make their smaller tools in Taiwan, often on the same assembly lines.)
Of course, a jointer without a planer is like ice cream without sprinkles. *sigh* It does add up. For a small furniture shop, I'd say bare minimum is 6" jointer, 12" lunchbox planer, 14" bandsaw, a router with a dozen bits. Or the equivalent in handplanes, bowsaws, and chisels. Plus the insane amount of time it takes to learn & use the latter.
Might look into Hitachi -- they make a small jointer/planer combo, which perhaps you could find used. Inca makes a convertible beast, but that'll hurt the pocketbook.
Re: jointer
Re: jointer
Steve Schoene
>Generally, bigger is better, since it will do everything a smaller one will do, but also allow face jointing wider boards. The 8" size is good, and opens up a lot of opportunities that aren't afforded by the 6". Go with 8" if you can swing it. Jointers are pretty simple machines and once set up, and not abused have very little to go wrong that isn't a matter of routine adjustment.
Beyond 8", jointers resemble aircraft carriers, and get quite large--and considerably more expensive. Generally above that size, the combination jointer/planer is more space effective (my 16" Hammer J/P) takes little more floor space than a 8" jointer--same length, a bit wider.)
Re: jointer
Re: jointer
Larry Clinton At Frankfort (Central)., Indiana
>As others have said - bigger is better. The jointer is a fairly simple machine & most if not all small units (less than 16") are Asian made. I personally think the Grizzly offers the best value - but many others will have their own preferences. I had a 6" Grizzly for several years - worked very well and was still working when I sold it to a friend. I purchased a new Grizzly 8" (G0593) with 75" beds, and the spiral cutterhead. The cutterhead has carbide inserts set in a spiral pattern , this makes it far less likely to "tear" or chip figured wood. It does a great job IMHO. The G0593 is on sale now - not cheap but a good unit. Their are several other good jointer's on the market. I would look at buying the largest you can afford as that will allow you to face plane wider boards and the longer jointer allows you to accurately join / flatten longer boards.
Re: jointer
Delta DJ-20
RobV
>It's an 8" blade and is all the jointer you'll ever need... I've had one forever and have never once longed for a wider jointer.
Re: jointer
Re: jointer
Andre Mallegol
>The jointer will probably be the longest truly flat surface you have in your shop. That said go for the longest table you can find.
Andre
Re: jointer
Rick L
Re: Silly question...
Rick L
>All brands of jointers would be considered reliable. The typical problem with all jointers is the rookie user. I strongly recommend you take some lessons from a veteran user especially in regards to changing knives. Also recommened you buy from a local dealer for service issues. Most times the operator doesn't know how to properly use the machine and blames it on defects in the manufacturing process, but defects can happen and the local dealer should have a real service department. Do not recommend buying used for the novice. I work on machines and deal with this stuff all the time.
Re: jointer
I'm insane, but
Neal in San Jose
>It wasn't a long learning curve to begin to get acceptable results using hand tools. My hand jointer plane doesn't care how wide a board is, and all of my stock now gets "sweetened up" by colesterol powered tools after it comes off of the electron powered ones.
