Re: OT: A/C in 2-storey house *LINK*
Rob Stokes in North Vancouver
>Denis - there may be a way....Here's the t-stat I mentioned: (linked below)
These have the capability to be networked. You probably don't need this. If you scroll down to the top of page 6 in the spec sheet, I believe this is what you'd need (pressure dependent VAV with auto-changeover. The first two diagrams on this page are similar, but they use different actuators - I prefer the analog actuator (over the floating actuator), but they're a bit more money.
Note that for this concept to work properly, each zone needs to know the temperature of the air that's being delivered to the zone. This is accomplished using a temperature sensor mounted in the duct. These stats are also capable of calling for heating or cooling, but this is where you could run into trouble with Trane as they have their own proprietary communications.
However - have a look at your existing system and see if it has the capability of adding a second thermostat (or remote temperature sensor). If so, you can mount the extra one upstairs (assuming your current one is down) and your existing Trane t-stat probably has the capability of averaging these temperatures and acting according to the average.
If so, the air handler will continue to operate the way it is now (it will make it's own heating/cooling decision), but the zoning t-stats will be able to make their own open/close decisions based on the temperature air they have being delivered. If hot air is in the duct and a zone wants cold, it will shut down and visa versa.
What this doesn't address is the duct pressure and I'm not sure of your existing system has the ability to throttle the supply fan speed based on this pressure. As the various zones close, the requirement for air diminishes and the duct pressure will rise. The air handler needs to respond to this by slowing the fan down. This same sequence needs to reverse if the zones start to call for more air.
If our current system can do this, great - if not, it's not the end of the world. In this case a piece of ductwork is run between the supply duct from the air handler to the return duct. In commercial systems we'd employ an actual pressure sensor and an actuated damper to control the air going through the bypass duct, but in thinking about it, you don't need that. You could employ a basic gravity-style damper that uses an adjustable counter weight. When the pressure increases, the damper opens. When it decreases, the damper closes.
Hope you have a big mechanical room!
Rob
zoning thermostat
