OT AC
Howard
>I think my shops window air conditioner is not working properly. Anyone know what the temperature of the air coming out of the machine should be?
Thanks
Howard
OT AC
Howard
Thanks
Howard
Re: OT AC
Tony - Memphis
>I've always heard a rule of thumb delta of around 17� or so. My window unit is very sensitive to debris in the coils. I take it out and wash it real good once a year. Amazing what that thing sucks into the coils.
Tony
Re: OT AC
>Tony is right. Use a thermometer to measure the air temp going into the unit and then coming out. Somewhere between 14 and 20 degrees. Oddly, less than 14 usually means lost refrigerant. More than twenty may mean the unit is dirty and the airflow is restricted. Sort of counter intuitive until you think it through. (the air goes through more slowly than it should and comes out colder than it should, because it lingers in the coils) So cleaning it may reduce the temperature difference but increase the airflow. Also varies with indoor and outdoor temps, so this test is unscientific.
