Dewalt 735 planer - no snipe?
John Peck
>I just got a great birthday present from my wife - a Dewalt 735 planer. A friend of mine has the DW734 model, and I was very impressed with the cutter lock, and lack of snipe. So I hinted that's what I wanted for my birthday, and my wife went one better! I was quite happy, since I was about fed up with my old Delta 12". My first board through was a nice piece of rosewood for the fingerboard of a guitar I'm building, and guess what? It sniped just like my Delta!
Has anyone had this experience? Is the deal that you have to buy the extension wings to make this planer not snipe? If there's some adjustment I can make on the machine for this, the mnanual certainly doesn't mention it.
Any ideas?
Return it for the less expensive DW734, and $150 bucks worth of other goodies?
Re: Dewalt 735 planer - no snipe?
del schisler
>i have this one NO snipe It has a bed lock Had mine for over a yr now works for me i thought about the dewalt but didn't like the review's this is just my 2cents here is the link
http://www99.epinions.com/hmgd-Tools-Benchtop-Planers_12i-Rigid-Ridgid_13_Thickness_Planer/display_~reviews
>John I got mine about 8 months ago and virtually no snipe. Occasionally I get something you could take out with 220 grit but mostly it's non existent. I also had an older delta which had huge snipe problems. Could it be the way you feed the wood. I always support it as I insert the wood and support the long end as it exits the bed. I thought about buying the extension wings but just haven't done it yet.
Mike Fitterling
>Snipe is caused by the end of the lumber being unsupported on one side as it enters or leaves the cutterhead. There is an infeed and an outfeed roller, one on each side of the cutterhead. As the board enters the infeed roller grabs it and sends it towards the cutter. As it enters the cutter only the infeed roler is pressing it down onto the bed. If at that time the trailing end of the board is pressed down, either through unsupported weight or a misadjusted infeed table the end of the board will hit the cutterhead and move on until the outfeed roller grabs it and presses it down flat on the table. This first cut is deeper than the rest of the board and is snipe. The same thing happens as board leaves the cutterhead, just in reverse. The cure? First make sure the outboard end of your tables are adjust so they are slightly higher than the planer bed, maybe 1/32" or so. As you feen the board in, lift the end slightly; this will keep the opposite end flat down on the bed until the outfeed roller can do that job. Once supported by both rollers, walk around to the outfeed side and do the same thing as the board leaves the cutterhead.
There are a couple other reasons you can get snipe. One is that the cutterhead assembly is twisting as the board enter, but that is what the head lock is intended to prevent. Also, a misadjusted bed roller can cause similar problems, however, your planer does not have those; they are usually on the larger induction run planers.
Here's a diagram showing what happens as the lumber enters the planer, which I hope will make things clearer.
Clay in Illinois
>John,
I have had the DW735 for a couple of years now and I get snipe if I don't apply slight upward pressure on the end of the board when feeding it into the planner as well as when is nears the end of a pass on the outfeed side. This is even with the extension wings. Seems to me the worst snipe I ever got was on hard maple.
Clay
Ray SW Ohio
>I have the Delta 12". I don't get any snipe with mine as long as I do what Clay mentioned. Just need to apply a little pressure to the board in and out.
>I had a little snipe before I installed the infeed and outfeed tables. After I installed the tables, I now get a very minimal amount of snipe, if at all. I think they were running about $40 at Amazon.
Kelly Anderson
>I used mine for 2 years without the extension tables without any problems.
