OT: Back after computer meltdown.
Henthorn
>Finally found my monitor problems were due to a failing motherboard. Had a new Asus installed and am now in the irritating. position of trying to get things on the new hard drive and doing a double boot between XP-home and Ubuntu. I have problems on top of problems and can't deal with most of the first level ones let alone the upper levels.(G) Found that Ad Aware is no longer free. Sound worked at first. Now the only sound I have is when Ubuntu boots up. Doesn't work on Windows or Ubuntu. Realize some of my Windows problems were because I had an OS on each drive and was confusing the booting protocol. Now, a question. If I boot up with only my old drive in the computer as the master will I then be able to delete XP-home from it and then reboot with it installed as a slave to the new drive? That would help me in transferring my data to the new drive.
I have a load of posts to catch up on.
Re: OT: Back after computer meltdown.
Chuck W
>Don,
You should do a new install of XP if you are using new hardware. No sound means you don't have the driver in place or the registry is fouled up. Select the drive you wish to use for xp, allow xp to format the partition and do the install. Have the driver cd handy.
Re: OT: Back after computer meltdown. *LINK*
John McGaw
>Huh? Ad Aware no longer free? News to me -- at least their "personal" version is still free as of a few minutes ago. I don't really have a need for their heavy-duty enterprise solutions.
Ad Aware SE Personal
Yes, I downloaded the "Free"edition.
Henthorn
>Installed it and then got a window that said It was a a thirty day trial and the thirty days started now. I needed a license to activate it. Maybe the thirty days was to get me to buy the license. However the ISP where my other web site is has an ftp program so I really don't need ws_ftp, but I do like the program.
I did a new install of XP on the new disk.
Henthorn
>that is why I don't want to install the old disk as a slave before removing the operating system. Windows boot doesn't like to be greeted by two operating systems.
Re: I did a new install of XP on the new disk.
Chuck W
>If you slave the old drive it will only boot from the new disk. Just make sure the jumper is in the right position. Are these IDE drives or SATA drives? If SATA then put the new one in the sata1 position and the old one in the sata2 position.
Dan Donaldson
>If you are doing a dual boot, the grub bootloader should give you the option of which windows to boot into. If so, just pick the new one and you should be able to get your data. I started out doing the dual boot thing, but finally decided to heck with it and deleted Windows entirely. I set up ubuntu to be able to read and write ntfs partitions, copied over all the data that I wanted, then reformatted the partitions to ext3. I still have one box that is set up for dual boot, but as soon as MS decides to stop supporting XP, that one will go straight Linux also.
It took me awhile to get everything working, but right now, I have everything that I need and it runs a lot better than with the XP install. The trickiest thing I had to deal with was getting the extra buttons on my mouse to do what I wanted.
You mentioned an ftp program below. Have you looked at the fireftp extension for Firefox? It works great for me, and is in a tab just like everything else. Really handy and has the features that work for me.
Did you do the reload of XP on the dual boot system? Usually, when you do that, it takes over the mbr and screws up the grub bootloader.
Dan, the old disk is so screwed up I don't think I
Henthorn
>can do much with it. There are so many things I don't understand, I don't know where to start. I thought I would take the new drive out, install the old drive as master and have everything like it was. Doesn't work that way. The new motherboard seems to remember that it was set up for double boot and wants me to choose without giving me choice. Yuk. By using the XP CD I can get to the install or repair choice, but the repair won't work because the old drive is named J not C. By closing out that screen and removing the XP Cd from the drive I can get windows to boot and then most everything works as before. But not everything. If I click run and type in %userfile%\applicationdata\mozilla\thunderbird\profiles\ it can't find it although I can go right to it.
Neither of my CD-rw recorders work with the old drive nor the new one. I am thinking of getting a small USB thumb drive to see if I can copy the profiles to that and maybe get my email and bookmarks transfered.
Most of my files are on the old drive named J and of course won't transfer to a boot drive named C. I do have most of them copied over to the new drive but can't access them with either XP or Linux.
In short I am a complete jackass just fumbling around hoping to stumble on something.
I do have xp-home and Ubuntu installed and working on the new drive. I have re-installed much of my Windows software but of course the data is still out of reach.
I am doing my surfing on Ubuntu but my email isn't responding, probably because my cookies are not loaded. I just keep on trying things.(G)
Re: Dan, the old disk is so screwed up I don't thi
Dan Donaldson
>I am not clear on what you said about having the files copied to the new drive, but being unable to access them. If the drive is working, you should be able to find the partition that the data is on and mount it.
If you have one drive that is dual booting, you should be able to put the other drive in the computer, boot up and then mount it to get the data from it. The bootloader should be using the boot data from the new drive and should not even see the old one. Linux should be able to mount the drive, and can read ntfs partitions. You can install a driver to give read and write access if that is needed. The thing that you need to watch is that sometimes when you add another drive, they get remapped as to drive letter or partition and that can cause problems, but there are ways around that one with a bit of work.
That is what happened some time ago.
Henthorn
>The old drive got remapped and my boot drive was named J. I now have everything on J including the OS, my programs and data. I don't have that drive in the computer because I was afraid of the new drive getting remapped and named something else. I did not transfer the data to the new drive as I implied but transferred it by dragging and dropping to an old Maxtor drive I had and I put that in as slave.
Think I would be safe if I kept the new drive in, which is now jumpered as master and installed on the end of the cable, and then installed the old J drive jumpered as slave in the middle of the cable? Could I then access programs and email and book mark settings?
I'll e-mail you so as not to take up more bandwidth.
