Adjustable Height Infeed Table
Dave Morris
>After making an outfeed table for my bandsaw (a few posts down the page), I quickly found out that supporting long odd-shaped pieces of wood by hand from the front of the band saw was "difficult" at best. I kept binding the blade, or changes in the wood's thickness meant the blade wouldn't cut a straight line as different parts of the wood registered off the short Kreg fence. A simple roller stand wouldn't work, since the wood was curved in both length and width, and some edges were very rough. Hmmm... gunna need an infeed table to control these curved wine vat slats.
Once again, shop space is at a premium, and if I can make something for one tool pull double duty on another tool, so much the better. Moving tipsy roller stands from place to place around my table saw is a dangerous dance, they are always in the way when not in use, and if not set to roll in a nearly perfect direction, they would bind the wood against the blade or fall over in mid-cut.... NOT good. So I decided to make a table that could be used on either end of my table saw (or on the side for cross cutting long stock or sheet goods), my jointer, my bandsaw, and also serve as a secondary odd-job table for "whatever".
"Project Priorities": Function, versatility, mobility, ease of construction, and utilizing whatever materials I had laying around the shop. Once again, my pack-rat tendencies came to the rescue, and I found all the major players in various rat-holes and sheet stock cut-offs. A few small bits of hardware were all I had to buy from the store. There's nothing like a new shop project to get rid of that piece of maple plywood you deemed unusable for a nice bathroom cabinet cuz it splintered so bad you couldn't drill a clean hole in it with your best brad point bits. (Grrrr...!)
First, the size of this table's top was determined by what was the left over from the piece of melamine I purchased for the band saw outfeed table. So a 16-1/2" wide by 39" long table top is the size I to which I matched the table's other components. I thought about the design, what I needed the table to do, and how I could use the materials at hand to make it all work. I had a piece of MDF that just fit the bill for the table's base, and a full set of old heavy-duty Darnell castor wheels for mobility--- two fixed, and two that were of the double-locking swivel variety. Okay, we're off to a good start.
A frame for the base was made from the last of the Sturdy-Floor scraps, and it straddles the bolts for the castor wheels. Problem... one of the bolts sticking through the base was in the way of the legs I planned to build. Changing that particular long bolt secured a hex-nut to a shorter bolt set in a T-nut fixed the problem. An outer set of 3/4" plywood legs was screwed and glued to the base frame, with an upper frame surrounding the legs for rigidity. An inner set of 3/4" plywood legs rests inside the outer legs, with an interior frame holding the inner legs together at their upper ends. A pair of crossbars straddle the inner frame at it's ends, and a piece of scrap ACX plywood between these crossbars gives the whole inner framework an "inner" table top and a strong anchor for stability. Matching 5/16" holes drilled in the legs every inch allow the finished table to be adjusted in height from 34" (just under table saw height), to over 53" (well over band saw height). Final height adjustment is done with carriage bolts seated in the crossbars, which support the melamine table top. Locked wing-nuts make decent handles to twist the carriage bolts using only my fingertips. Lifting the melamine top off the inner frame lets me use the ACX plywood "inner table top" at a table height equal to my jointer. Why my jointer? Well, I occasionally work with 10-foot (and longer) reclaimed lumber, and getting that first edge clean can be a real handfull on a 6" jointer.
A frame around the table top gives the melamine rigidity, and is sized to fit the crossbars front to back and side to side with about 1/8" of clearance. I placed a set of nail-in-place cushioned metal glides on the underside of the melamine where the carriage bolts contact it's surface, thinking it would reduce friction so turning the bolts by fingertip would be easier. They worked... in fact, they worked so well I had to add a couple pan-head screws to the crossbars to take up the slight amount of slack I planned in the top's fit, since it moved back and forth with the touch of a finger.
Problem-- my shop floor isn't perfectly flat everywhere, and we all know what happens when four contact points are not all in the same plane... wobble. For those locations where one of the four castor wheels isn't touching the floor, I added another carriage bolt through the MDF base, located between the swivel castors, to give the table an additional adjustable "foot". A crutch tip slipped over the end of the carriage bolt gives it a good bite on the cement to help prevent table movement.
The table isn't too hard to adjust, just lift the inner frame as high as needed and stick a 1/4" bolt through one of the matching holes in the inner and outer legs as they line up. A single bolt will keep the table from dropping, sticking one in each leg keeps the table from "tweaking" when a load is placed on top. The weight of the top keeps the bolts in place, so I don't have to worry about fitting a nut on all the bolts each time I change the table's height. I'll scribe lines on the legs to correspond with the height of each tool, to make setting the right table height for each tool less of a shot in the dark. I admit tossing around ideas for lifting the top by means other than muscle. The first thing that came to mind were those little pneumatic lifts used for car hoods and/or a camper shell's glass "win-door", but couldn't find any with enough travel to match the table's full range of adjustability. I also considered a system of pulleys, cables, and springs to bear the top wieght, but didn't want to get too complicated, or spend a lot of time/money on a simple shop table.
The space between the lower table legs is a prime candidate for storing "something", and I'm thinking a set of those multi-drawer nut/bolt/widget storage boxes from Wally World might be just the ticket. We'll see how that pans out before the next project starts.
Again, this is a quickly built shop table, not fancy wood work. Screws, bolts, or butt-joints dripping Tight Bond hold everything together. It ain't pretty, but I gotta admit, using up some of the left-over stuff cluttering the shop is a thing of beauty. So far, I'm happy with how it has filled the "Project Priorities". However, your thoughts and advice on how I could do a better job next time are welcomed. I'm always willing to learn from my mistakes, even if someone else has to point them out. ;-)
Below is a pic of the table set for the Table Saw.
Dave
