Have a question? Ask Woody!
Router Table Upgrade Question...
Rob Hix - King George, VA
>Hey all,
I am about ready to build an outfeed table onto my tablesaw. I am putting my router table into the outfeed table. I thought that I would take this time to update the fence system on the router.
My new Woodsmith came in the mailbox last week and I was intrigued by the Incra Universal Precision Positioning Jig. For $60.00 for the jig and $100.00 for the jig with a coupl of extra accessories, I was wondering if it was really worth it?
I went out and looked a the other Incra fence systems. They look really nice, and it looks as if they would allow for a variety of joinery applications. First, are they really worth the price they command? Second, if you were upgrading your router table would you use the $60.00 jig or try to go for one of the other fence systems? Third, which of the other fence systems would be best?
Thanks in advance for the help,
Rob Hix
Rob Hix
Re: Router Table Upgrade Question...
Dave Bair, Eaton Rapids, MI
>I did the same thing you're contemplating; but I use the table saw fence as the base for the router fence. I attach (clamp) 2 2"x4"x15" maple blocks to the fence, on the router side, when I'm doing routing and remove them when I'm done. I also clamp the free end of the fence to the saw's rail to keep it from flexing. The blocks form a split fence and are positioned far enough apart to barely accept the router bit. For some cuts, I need to shim the out-feed block to accomodate material removed by the bit.
jeff
>I run 4 router tables in my shop.
I've used the Bench dog, Jessum, Jointech, and Incra at one time or another.
Yes they all work.
My advice is simple.
Get a router lift with above the table bit changing.
And unless you plan to buy into the special features for making fancy joints that depend on the Incra system, forget it.
I have the Incra set-up you're looking at and hardly ever use it.
Most of the router table use is with a simple fence.
While I have some fancy fences, a simple wood fence with clamps on both ends is my usual choice for most work.
Jeff
del schisler
>check this site it has many item's that i use And i have the table and lot's of their stuff click on the left side for items
http://us.oak-park.com/catalogue.html
Router Fence Pic #1
Jim Dillon
>Rob,
Unless you are really hot to buy the Incra fence, why not build your own? I built a fence based on a quick sketch from an episode of NYW years ago and it has worked well. Because of space limitations, I put the router into the table saw extension table (not the outfeed table). Here is a couple of pics. If you are going to really put the router into the outfeed table, make sure it is completely level with the surface of the outfeed table to insure you don't catch the lip of any boards you are sawing. Oh, if you are really interested in a micro-adustable fence, the woodworking author and router guru Pat Warner had a neat fence in a past issue of FWW. Good luck.
Jim
Re: Router Fence Pic #2
Jim Dillon
>Jim,
Thanks for the pictures. As I have thought more about it this weekend, I think my main fence will be just a simple fence like you show. I do think at some point in time that I would like to get the Incra jig just for the joint making capabilities and the templates you can get with it.
I have seen Warner's fence, and in my opinion it (like a lot of his jigs) is WAY TOO complicated. I will probably come up with some way to get the micro-adjust capability.
Thanks again,
Rob Hix
