Woodworker II worth the money?
Joe Pack
>I sold my table saw recently, but forgot to switch out the Ridge Carbide blade before I sold it. I have a couple of cheaper blades to make do for now, but I found out I can buy a Woodworker II for $80 delivered. Is this blade worth the $25 or so more than buying a Frued or similar blade?
Re: Woodworker II worth the money?
Keith Weber
>Joe,
This subject comes up quite often, and the replies always come out the same. That blade is well worth the money, and that is a good price you mentioned. You'd be hard pressed to find any negative feedback on the Woodworker II.
Keith
Yes, it's worth it. But I like Duraline A/T better
HC Sakman
Dan Manturi
>The Forrest blades are incredible. I remember when I bought mine for $100. The difference was amazing compared to anything else I have used.
Dan
del schisler
>here is the blade i like Delta for less money and is just as good Read the reviews http://www.amazon.com/gp/product/customer-reviews/B00008K2TZ/sr=8-1/qid=1158097776/ref=cm_cr_dp_pt/102-6988256-2750539?ie=UTF8&n=228013&s=hi&qid=1158097776&sr=8-1#customerReviews
well here is some negative feed back
Bill Tindal, E.TN
>These blades gum up and get dull quicker than blades made with more "set" and they cost twice what a good quality combination blade costs. Note the amount of marketing these blades support and believe the price you pay supports this marketing.
The main selling point of these blades is the tooth mark-free cuts they make. I find this advantage is only rarely significant in my woodworking. Compared to the disadvantages noted above I don't see good value in these blades.
These blades gum up because they are made with very little side clearance on the carbide teeth, compared to most blades. I was told at the saw shop that the gum build-up was the cause of dulling. So maybe if they are cleaned often, something I never have to do with other blades, they won't dull as quickly. See more on the theory in the article in the Articles section.
How to tell when the blade is dull? Look for splinters at the cut exit of woods like oak and walnut when cross cutting.
Re: well here is some negative feed back
>I agree with Bill. I have WWII blade and I like it, but I don't think it is the only good (excellent) blade out there. Before I bought it I used a Magna blade that I bought on the closeout table for $15. It was a thin kerf blade and did most of what the WWII blade will do. Might not have produced the perfect "glue-line" cut, but I have a jointer, and probably ninety percent of what I do on a TS is not even aimed at a glue-line. I like my WWII and use it everyday, but it�s not wroth 7 times what the Magna blade cost. In fact, when I needed a utility blade to rip about a mile of stickers, I bought another Magna for about $30.
I have no experience with the Freud or other blades mentioned. (Freud does a lot of marketing also) I have one or two blades that were crap and pretty much a complete waste of money. Spend $40 and get nothing you would use or spend $80 and get a good blade. You do the math.
Forrest makes a blade that cuts a flat bottom cut. If it is otherwise as good as a WWII, I would rather have that. I occasionally want to sue my blade for nibbling out a dado or tenon and it would to a nicer job if it did not have the ATB Grind.
I have never cleaner my WWII, but maybe I should. I am a lazy woodworker and would rather not change the blade. I want to just use the saw for whatever I am doing and not bother with the blade. The WWII lets me do that. It does both ripping and crosscutting well enough that I just use the saw without have to rethink the blade for every cut. That�s worth a lot to me. I do change it out to protect it from wood I am suspicious of.
Yep!
Bri in Mtl
And here's more
Henry Higginbotham
>I bought a WWII several years ago. Absolutely beautiful cuts . . . for about five minutes. After that, no amount of cleaning and care that I could (reasonably) do would keep it from gumming up and dulling. And, no, I never cut any pine with it.
I recently sent it to Ridge Carbide along with several other blades for sharpening, and asked that they see if they could make it useable. I haven't tried it yet, but they did quite a bit of work on it, and it LOOKS like it will be much more useful. Couldn't be any worse.
OK blade-yes, worth the money, NO
Wayne Allen, Carson City, NV
Matt Robinette,Mt Juliet TN
>It is a great blade and will last longer than less expensive blades because of the amount of carbide that is used for the teeth. They are huge.I am not sure how many times it can be sharpened but it is a bunch. I like my CMT General 40 blade also with it's teflon coating at about half the price but the carbide teeth are half the size at least.. I only have one Forrest WWII but a whole lot of CMT bits and blades and have yet to be disapointed by CMT.
Matt
Patrick Schupbach
>I own a WWII and think it does a good job. Jesada makes some good blades as well. I own the thin-kerf ripping blade and it is an awesome blade.
Nelson
>Not really, 15 to 20 years ago they were better than anything on the market and I bought one and its a good blade,today Freud and CMT makes blades just as good for less money[several other companies also] we all got caught up in the hype by write ups in Fine Woodworking and other mags that we had to have this blade or we were not good woodworkers. I will never buy another Forrest and stick with my Freuds and CMT'S, just my 2c's worth.
I have that flat bottom Forrest
Neal in San Jose
>I picked up one of those flat bottom Forrest blades and like it a lot. It is simply a regular WWII with a flat ground on the top of the teeth that goes 1/2 way across, leaving the angle on the rest of the tooth. Since the teeth alternate, this results in a perfectly flat bottomed cut. Mine is the full kerf (1/8") version, and it is very useful for cuttng slots and dados, even the odd tennon when I don't feel like setting up the tennon jig.
Forrest sells the same blade in other thicknesses from (I think) 3/32" up to 1/4". A pro friend of mine has several different sizes that he uses the heck out of when he sets up for production runs. He loves them for cutting finger joints, slots for drawer bottoms, narrow dados, etc.
However, after saying all that, I use much cheaper Olsons for my day-in day-out sawing. I have two combo blades so I'm not out of business while one is out for sharpening, as well as a rip and a crosscut. IIRC, I got a three blade set at a woodworking show for about the price of one WWII. Like others have mentioned, I can't really see the difference in cut quality being that great, and most of my saw lines get sweetened up with a Stanley #7 anyway. YMMV Neal
I stand corrected!
Keith Weber
>I guess there are people that don't like the WWII. It's been a good blade for me. For me, the cuts have always been smooth. It is an all-round blade. I'm sure that there are better ripping blades and better crosscutting blades, but I'm still happy with mine.
Keith
reworking the WWII blade
Bill Tindal, E.TN
>I have Misenheimer in Morristown TN do my saw work (they make cutters for the woodworking industry). They told me that they grind some relief behind the tooth insert if the customer allows it and that reduces the pitch build up.
I Don't Fault The WWII's Performance either
WOODWORKER 11
robert davis
Completly satisfied with my WWII blade.
Howard Norman-Prescott, AZ
Tom Stockton
>I have a 12" with 40 teeth and only use it when I need the extra height. The two that stay on the saw are a Systamatic and an Evelast both work well.
Tom
Larry Clinton At Frankfort (Central)., Indiana
>I personally believe they are worth the money to me. I have a Delta / Tenyu (sic) blade that came with my Unisaw - it is a good blade but not up to the WW2 IMHO. Guess I'm unique, I have not had problems with my blade "gumming up" excessively. I think I cleaned the blade twice in a couple years. And yes I did cut a lot of wood during that period. Several hundred running foot of White oak, a hundred or so of Poplar, some Western cedar and several hundred feet of Locust along with some misc. pine, Walnut, MDF and lots of hardwood plywood. I just took the blade to my local sharpening service a couple weeks ago. I haven't tried it out since sharpening but will probably install it this week. The local sharpener had computer controlled sharpening equipment and does a lot of commercial work so I'm sure it will be the same as it was from Forrest. I intend to buy at least one more WW2 - and maybe one of the flat bottom cutting versions in the next year or so. As an additional benefit the WW@ is MUCH quieter running than any other blade I have used.
Tony - Memphis
>Well, for what it's worth, I have been using one for around ten years. I have been very happy with it. I've never compared it to another because I never needed to. I am a weekend warrior, mostly cutting 4/4 mahogany, cherry, and some maple. My blade has never needed sharpening and it doesn't seem to get gummy. $80 is a good price. Seems like I paid $107 for mine. Oh, mine is a thin kerf.
Tony
Wayne Stump
>I've owned and used a WWII for about eight years and been very pleased with it. I sent it back to Forrest for some repair when I bent a couple teeth, but other than that it has been on the saw almost constantly. Admittedly, it's not quite as sharp now as before I sent it to Forrest for repair.
If you're looking for something other than the Forrest, one of the members of the local WW club mentioned a new Delta blade that was very impressive. It might be worth looking in to.
