Blum Minipress
Blum Minipress
Blum Minipress
jeff
>Hi all
Anyone have a Blum Mini press or work with one?
I picked one up on ebay, but no bits.
Do they rotate in reverse and require reverse drill bits?
Jeff
Re: Blum Minipress
Re: Blum Minipress
>I'm pretty sure the main bit, which is 35 mm for the hinge, runs clockwise like other bits. I can look for sure on Tuesday but not till then ;) The bits that drill the holes for the press in hinge, which is where the screw holes are located, need to be a matched pair, one drills clockwise and the other counter clockwise (this is all from about a year old memory when we set up our first press, and therefore is suspect, but I'm pretty sure that is right). I am not sure about the shank on the main bit; it may be a special shank. If you do a lot of kitchen cabients the Blum mini press will save you a pile of work. We use the press in hinges and have had no problems with them.
