Re: Vertical Push Stick-Pic#1
Jim Dillon
>Doug,
IF the top of your router fence is flat, you might be able to adapt this very basic design to your needs. I used it to rout the narrow ends of drawer sides with a drawer bit. My drawer sides were not quite as long as yours (maybe 20 inches or so) but you could extend the upright piece and even add a couple of De-Sta-Co clamps to help out. You could even design a cleat that extends around the top of the fence to give greater stability. Plus the support piece helps minimze tear out.
Pic #2 shows the same support turned on its side. By making the gap between the fence and the horizontal support the same width as your work piece, the bottom of the work piece is held against the fence. Using the jig in this position, you could extend the vertical piece upwards and add the De-Sta-Co clamps. I found this easy-to-make jig very helpful for achieving a safer cut on narrow workpieces. Good luck.
Jim
