Anyone Serviced a PC 333 VS ROS Quicksand ROS?
>I have the PC Quicksand ROS. It has stopped working well. (Motor runs, does not sand well and makes strange noises)
The big O ring in the bottom under the Pad is in place and in good condition.
When I took the pad off to check it, there is a screw in the center with a black "washer" (?) around it and there was black rubber shreds coming out of that area. About the size of a quarter. I suspect it is what ever it uses to impart the motion from the motor to the pad. I think the big O ring is a "governor". Went to Service Net and tried to look up the part in the exploded drawing, but the quality is poor and the number is missing off what I think is the very part.
Anyone got any sage advice here?
Re: Anyone Serviced a PC 333 VS ROS Quicksand ROS?
>Hello Barry,
Get the exploded diagram in view and call the nearest P+C Service center. You should be able to "talk" them through and identify the missing part number. You'd contact them anyway to order it. They may have another idea of the problem's cause.
George
>Thanks George, I took the screw out of the center of the base and the washer like part came off. There was some sicky crud there that I decided was supposed to be there. I think an O ring about the size of a quarter is missing. I will take it to the service center soon. Hope they will either fix it or tell me how. The worst part is making two trips.
Call Them First Barry
>Maybe you can avoid even one trip to the Service Center.
George
