Irwin Marathon table saw blade
>When I finish my kitchen remodel - and I can imagine that I will - I'll be finishing the repairs on the 10" contractor's saw I bought for $50, and then I'll need a blade. I can't afford a $100 blade, so am looking at lower-cost alternatives for a combination blade.
Rockler's got the Irwin Marathon 40T blade on sale right now for $30, even throwing in four of those trigger-tightened bar clamps with it. Is this a good blade? Are there better ones in this price range? If I pay $40, are there blades a step better yet?
Re: Irwin Marathon table saw blade
Chuck Lenz
>Bill, theres nothing wrong with Irwin blades, but if I was looking to step up I'd look at Freud. They make some nice blades at a reasonable price.
Stuart Hough
>I'll second that. I tried a Freud blade on my table saw after a few cuts with the original Craftsman blade. The Craftsman blade was no slouch, but I was astonished how much better the saw cut through 4/4 and even 6/4 stock. The Craftsman had only seen a total of about 10 minutes use, but the Freud was just fantatsic! I reccomend their newer Avanti line in a combination blade. It will likely be the only blade you'll need for a long while.
I'd Second Freud's Blades Too
Howard In Toronto
Sawdust Everywhere!
>I would stay away from Irwin. They dull very easily. Don't know why.
I have had better luck even with the cheaper Freud Diablo blades on my miter saw (D1040 $29 from BORG). The diablo series is thin kerf designed for contractor saws and portable miter saws.
But I would recomend the full kerf Freud woodworking blade. They're far better. Only slightly more expensive. Lasts a lot longer.
Re: The one Irwin I bought
Glenn Madsen near San Francisco
>was just ok, even after a professional grade resharpening. So it's an emergency blade now. My sharpening guy (Bay Area Carbide, in Concord) sells, among others, FS Tools blades. A pro grade tool, at a reasonable price. I've got three of those now for the Unisaw, and none was more than $60, even with a custom grind.
I have a Freud Diablo rip blade, thin kerf, which works pretty well, from Home Depot. It gets used, but I don't go looking for it regularly.
Those Rockler specials are of variable quality. Some just great; some not so special, IMHO.
Dan Manturi
>You are getting good advice here. Irwin - I had one early in my woodworking days and it worked, as someone said, OK. Freud is my everyday blade and the work very well for them money, and perhaps you can seek out some old blade reviews on the internet to see which model Freud works best, but they are all decent. A good combo should do the trick, and if the saw is low powered, thing kerf would serve you better.
Dan
