200+ woodworking book reviews
Flag Case Dimensions?
Dave Morris
>Hi all, been gone for a while. My Father In Law, Wolfgang, passed away on the 10th, and now we are all back home. I'm so glad we were able to visit my wife's parents last month during spring break -- we'd hoped to see him again after school broke for the summer, but the cancer moved much quicker than the doctors thought. We will all miss him dearly.
His flag was given to my Mother In Law at his funeral, but there will be an additional ceremony later this summer. She wishes my wife to take possession when the time comes. I'd like to make a flag case to give her mother at the military's dedication ceremony for Wolf's marker, and have searched this forum for examples. I have never seen a flag case in person, and the pictures that turned up in the Search don't include sizes. Please... what are the dimensions of a folded flag?
I've got a nice piece of walnut, and some really stunning flame-cut redwood burl I've been saving for that Certain "Special" Project. This is about the most Special woodworking project I've ever taken on, and I'd like to do it justice. Thanks for any help on traditional joinery used in flag cases (if there is any), or tips you've found out the hard way when making these triangular cases.
In many ways, this is a most fitting weekend to ask this question. Rest In Peace, Wolf, you served our country well.
David
Re: Flag Case Dimensions?
Dale Lenz
Dale Lenz
>From my dated FAQ file:
FLAG CASE DIMENSIONS
Hello and thanks for inquiring about the flag case I presently have for sale on Ebay.
Flag Case Dimensions are giving by width x height (bottom to top, not side measurements as many flag case business give) x depth.
The inside dimensions are the following: 21.5� x 11� x 3�
The outside dimensions are the following: 23.75� x 12.5� x 3.25�
I�ve been building flag cases since 1993 and have noticed a few things about the Veteran�s Memorial American flag due to customers coming to my home and asking me to put their Veteran�s flag in their flag case. As we all know the Veteran�s memorial flag is the same size, approximately 5�x9�, but the folded flag can be slightly different in size due to two of the following reasons:
� The weight of the material used in making the flag
� How the flag was folded, tight, lose or somewhere in between.
I have built 300+ flag cases over the years and have �tweaked� the flag case size to where all Veteran�s memorial flags have fit to this date. The flag may need to be refolded, but they all have fit, generally with out refolding. My flag case�s dimensions maybe slightly smaller then the measurement of your folded flag but once again I have learned that the flag displays much sharper in slightly tight quarters. As my item description states, I will guarantee your complete satisfaction or I will refund your money including the return shipping cost.
I hope to hear back from you,
Dale Lenz
Dave Morris
>Thank you, Dale, for the help. I checked out your web site, beautiful workmanship!
Cupla questions... I noticed the flags in your cases have four stars showing (three in a row below, one on top), while other plans (this, for example-- http://woodstore.woodmall.com/flagcase.html ) show six stars in a "two over four" pattern. Question One: Given the flags are the same size, is there a traditional way of folding the flag so the stars showing are in a particular pattern and the flag is a certain size? I don't have access to my FIL's flag since it's over 1000 miles away in another state. Taking measurements without alerting my MIL will be kind of tough to accomplish and I'd like to surprise her with the case on our next visit.
I like your mitered and double splined corners, that's pretty much the style of joint I'd wanted. But I have one idea concerning the "look" of my choice of wood--- I plan on cutting all three sides from a single large piece of redwood burl slab, and would love to bookmatch the pieces in a manner so all the mitered corners "flow" together. Sort of a "head and tail" approach to bookmatching the face grain when ripping a thicker board on the bandsaw (hope that description makes sense). I'm having a hard time mentally visualizing the cutting and/or piece rotation steps to accomplish this. I have two slabs thick enough to cut the pieces either side-by-side through the slab for the width of the cases sides (one is three inches thick, the other is four inches thick, both are long and wide enough to cut the case sides from a North/South or East/West direction), or "stacked" so the case sides are taken from "cake layers" cut from the slab (again, hope this description is clear). Question two: Is there a way to cut these 3 pieces out of a slab to accomplish the flowing grain on the corners so the 3 case sides truly look as if cut from a single larger piece of wood?
I'd appreciate your thoughts on either of these two questions.
Dave
Dale Lenz
Dale Lenz
>Answer to question #1. The stars in my flag case's flags are something like 3.5" in height and width. Some Veteran flags have smaller stars, hence the viewing of the # of stars. You can play with folding the flag and then tuck and cuss, at least I do : " >, to get the flag to show correctly. Honestly it's a pain, but can be done, the owners of the flag case will literally get some of my sweat on their flag. The simple way: cut a piece of dark thin cardboard slightly less than the inside dimensions of the case. Prior to folding the the flag "all the way up" insert cardboard behind the blue field of the flag and adjust and test fit. When satisfied, neatly "lay/fold" the remainder of the flag in the case and close up. The reason for a dark cardboard, many Veteran's flags are made with thin material, IE you can see the red and white strips behind the blue field, so if you use a light colored cardboard it will show through. I will often spray paint the cardboard a flat black, if needed. BTW, large desk calandar cardboard works well, but needs painted.
Question # 2. If I understand your question: yes you can do the length wise book-match thingy, never have done that myself and your last corner will not match up. If viewing the flag case as a map and the front top of the case is North and you are working in a clockwise direction, the SW corner will not match.
What I do: find a length of lumber 38"+ in length, and cut in half, as in half of 38"+ = 19"+ mark A A near the cuts on each board facing the same direction before you cut it. Find a "nice" match for the bottom board. Re-saw the face frame material out of thicker material, for a true book-match. Once again find something close for the bottom face frame. Glue on face frame and then work on cutting my miters and glue up.
Hope this helps. Dale
Re: Flag Case Dimensions? *LINK*
Glenn Madsen near San Francisco
>Hello, Dave! Sorry to hear of your loss...
The link below is to our woodworkers' club pages, where we have instructions and history on our flag case projects. Maybe there's something there to help with your project. I worked on batch 2 of ours, done a couple of summers ago. We still provide cases for vets and public service types who go too soon. And I built one to honor an old friend who had been a real help to me and my family for decades.
http://www.diablowoodworkers.com/flagcases.html
Dave Morris
>Good explanation, Dale. Knowing that different flags may have different size stars explains my confusion on the number of stars displayed in different cases when the flag is folded. Good tip on the cardboard backer, too. Guess the end result doesn't make any difference, since the object is to display the flag itself, and not a certain number of stars.
Bummer about bookmatching the miters. I was afraid getting a bookmatch on all three miters wasn't possible... I couldn't play any cut/flip/rotation scenario in my head and make it work. Now I know why. I'll just have to play with the pieces and come up with the best match.
Thanks again,
Dave
Dave Morris
>Thanks, Glenn, for the sentiment, and the link.
Dang, Jeff's shop is too clean! I'd be afraid to show pics of my whole shop in all it's (un)glory. Got a couple good tips from the pics, I especially like his spline jig. It looks like it registers off the miter slot, and is quite a bit wider than the one I made for cutting spline slots in mitered cabinet doors. Mine was kinda clunky, using a "h"-frame to capture the fence as a guide. Yeah, I could adjust the placement of the cut, but it made *exact* duplications very touchy if I had to remove the jig and adjust the fence for a different job.
Nice how-to on the web site. Man, that's quite a production run you guys had. My compliments on a most worthy undertaking.
Dave
Re: Spline jig registration
>Yes, Jeff's shop is a piece of work. He's former oil industry, and somewhat of a gearhead, for a woodworker. His shop does wood and metal, so he has to keep it really cleaned up.
It's a nice spline jig. It registers off of the table saw fence, or at least the version that I made does. And it was from his instructions. They're really easy to make, and when you wear them out, make another one pretty quickly. But they only wear out when you change the offsets a lot. When you're doing a run of 50 cases, there's really no changing.
And this is where you'll want one of those flat bottom groove table saw blades, too. Either a custom grind, or a piece of an appropriate dado set. Or run it on the router table, I guess. I've never done that, but with a slot cutter, it should work out all right.
