How do the experts do it?
Pat Evans
>I know the answer to my question is going to be experience and skill, but that won't help my immediate problem. I'm making drawer fronts of oak veneer plywood with 1/4" oak edge banding with a slight bead detail on the front edge. My problem is getting the mitered corners to close tightly and also have the edge banding fit tightly with no gaps. I'm using a miter trimmer which was carefully adjusted such that four test pieces arranged in a square meet exactly at all corners.
Despite careful measurements and even more careful cutting and trimming, when I've got glue all over the parts and am trying to get everything clamped together, the corners just aren't looking as good as I think they could look. Is there a secret to getting good mitered corners in a trim application like this?
Re: How do the experts do it?
Some experts use wood filler!
Ron Hildreth, Alta, Iowa
Re: How does a non-expert do it?
>Good Afternoon Pat,
It is fussy work. I am doing a master bedroom suite which has the same feature, only in cherry. What I did was to fit the bead to the face frame on all four sides of the drawer opening. Then I cut the 1/2" drawer face to be very slightly proud of the interior dimensions. I sweetened the fit with a block plane. Trial and error. When I got a perfect fit, I glued on the beading to the drawer face. A couple swipes here and there with the plane afterwards is all it took. It doesn't go real fast, but I think the effect is well worth the effort. So far I've completed two night tables with four drawers each, and the learning curve was five drawers.
George
Re: How do the experts do it? *LINK*
Bob Lang
>First thing is to make sure everything fits without glue. If the drawer fronts aren't square, and the pieces of trim aren't the exact length you will have trouble. Mark the lengths of the trim pieces directly from the edges of the drawer fronts-don't try to measure.
Often times you get things to fit and then they slide around when you go to glue them on. Two suggestions:
either tape the corners together with clear packing tape or use miter clamps (link below)
hold the trim to the edges of the drawer fronts with some discretely placed 23 gauge pins.
hope this helps,
Bob Lang
Miter Clamps
How I do it, slow but sure
Bill Tindal, E.TN
>This is slow but results in perfect miters. It sounds like you are trying to do all four corners at once? I could never do all four at once. The following approach does not assume what the molding is going around is perfect 90 degrees, and it probably won't be. Definitions: let the top piece be called 1, the right side 2, bottom 3 left side 4.
1. Cut 45 degree miters on ends of all pieces, making each piece 1/32 to 1/16 longer than where it goes. I make the length measurement off the piece to be molded.
2. Test fit each corner to see that the miter closes perfect. For now let us assume they all close fine. More later if they don't
3. Line up the miter between 1 & 2 perfect. Let go of 2 and test fit 4. You should see that 1 is the 1/32 or 1/16 too long. Securely holding 1, scribe across the left end where it overhangs its 1/32 or 1/16. Next nibble most of this over hang off. I use a shooting board as I can nibble about 0.003" at a time. Nibble and test, nibble and test. When the length fit on 1 is perfect, secure piece 1 with a couple of brands partially driven in.
4. Now move to the miter between 2 and 3 and repeat the process used in step 3.
5. Repeat for remaining joints. When all is perfect counter sink the brads.
6. On a large molding it is common for some miter to not close perfect. In this case the angle can be adjusted in the nibbling operation while the piece is still over sized. When the miter angle is adjusted perfect, then holding that angle nibble to length.
Larry Clinton At Frankfort (Central)., Indiana
>I'm sure not an expert (if I were I wouldn't have to use this trick) but I have closed some corner joints with a smooth screwdriver shank. Carefully rubbing the edge will move enough material (before finishing) to close up small gaps. IMHO it works better than wood filler.
>I am no expert, but I have done this a few times. I believe you are talking about what I call a Cock Bead. A amall beaded trim run around a drawer or door. Mine were closer to 3/16 thick than a 1/4".
I back beveled my drawers about three degrees. That is, I ripped them on the TS so that the inside face of the drwer was slightly smaller than the outer face or the drawer fronts were tapered like a cork. This allowed me to have the front side nearly an exact fit in the opeing, but there was plenty of clearance on the back to allow the drawer to close without snagging the back of the front.
I ripped a rabbet into a scrap strip of wood with the same angle. I set the strip in the bed of my ancient chop saw. I cut the left end of all the cock beads, leaving them too long. Then I shifted the rabbetted strip to allow me to do the right end and then proceeded as Bill suggested. Worked one corner and taped it in place, Then went to the next one. By using the rabbeted strip in the chop saw, I got a compound angle on the miter. I am not much of a hand tool guy and don't have a shooting board, but I think this rabbeted strip served the same function. It very accurately held the pieces and I could shave off an extremely small nibble. I recently did six drawers and only used a couple of the spare pieces of cock bead I had made just in case. On very thin pieces the miters should close better or at least any errors will be far less visible than on wider molding or crown molding.
If you don't want to do the back angle thing, the same idea will work, just rip the rabbet in the support strip at ninety degrees and you will cut simple miters.
Also, you must mark and work from each drawer. I found a pencil mark to be way too wide. I used a knife and good light. Patience and sneek up on it. Blue Pinters tape makes a great set of extra hands for this. Does a great job of keeping finished joints in place while you work the others.
George - tolerance question
Pat Evans
>I've gotten some great responses and much needed help. However, your response intrigues me as possibly the easiest method. While my application doesn't have a face frame, it would be simple to build a quick jig to simulate a face frame. My question for you though, is about tolerances. Your description sounds as if there is zero clearance between the trimmed drawer front and face frame. Did I misunderstand?
Thanks
Pat Evans
>I appreciate all the great advice. I didn't totally screw up, but there are several things I will definitely do better next time.
Re: George - tolerance question
>No Pat,
You didn't misunderstand at all. Once the beading is wrapped and glued around the drawer fronts, I take it back to the face frame and insert it. If I have a wee bit of trouble, I use my LA block plane to remove a couple thous until it fits snug. Then I attach it to the assembled drawer boxes, and plane a little more where needed. I know I'll get some movement and binding sometime. But I don't know when that will happen, as these pieces are still works in progress. The solutoion to that problem when it occurrs is to shave off a little more.
George
