OT-Bats in the belfry and those ivy covered walls.
Gary Evans Tallassee, TN
>Hi all,
I've run into two issues with rehabbing this old store building. I am looking for eco-friendly resolutions for both.
First off are the bats. I'm getting ready to close off their access into the building, but I'd like to chase them out first. Does anyone know if the sonic devices are effective? I hate to spend the money if they aren't. Any other suggestions would be appreciated.
Secondly, I have a large growth of poison ivy on the back wall. 8'x20' at least. I know I could buy a poison that would resolve the situation, but I hate to kill every other plant in the vicinity. Any suggestions on a safe way to get rid of the stuff?
Thanks,
Gary
Re: OT-Bats in the belfry and those ivy covered walls.
John McGaw
>Bats: I'd try to contact the local wildlife preservation group so I could tell them the situation. They might be willing to come and catch the critters for relocation but even if they don't offer they should have some valid ideas. I normally would suggest the TNWRA but my experience suggest that if you can't hunt or hook it they don't have any interest.
Poison Ivy: if it is of the massive sort -- the big hairy vines the size of your wrist -- then it is easy to kill by cutting it off at the ground and then applying concentrated Roundup or other glyphosate herbicide to the cut ends with a brush. If it is the routine infestation of little plants then you an either apply normally-diluted herbicide to the leaves by brush (a tedious task, believe me) or sacrifice the other plants and spray the whole bunch. Plant indigenous wildflower seeds afterward to salve your conscience.
Be glad that it isn't English ivy. Poison ivy is simple to kill most of the time but the other is as close to unkillable as any plant I've seen and makes kudzu look like a wimp.
Dave Bair, Eaton Rapids, MI
>If the TNWRA, as suggested by John, won't help, try closing off the bat's access after they have left for the evening. Although, at this season, you'd probably trap some young-of-the-year who aren't yet able to fly. Local animal control or the SPCA may also be resources you can try.
Scott in Eastern Iowa
>Gary....those sonic traps are all worthless. Ive not heard of anyone that can document to me that they are effective.
Dont waste your money on them. They do not like to be sprayed with water however....so thats a cheap way to move them.
As mentioned the best time to shut them out will be nightime...but your likely to have young ones who cannot escape most likely. Id ask a extension or pest control person when they usually have young and the coast is clear to do this. You may have to bit the bullet and just do it Im afraid.
If you have problematic poison ivy that keeps growing off the mother vine, cut the vine close to the ground and then dig a "cup" into the exposed section of the vine stub remaining. In this excavated "cup" pour to the rim your strongest roundup solution and cover with a baggy or piece of plastic then secure the plastic with a rubber band. This will keep the roundup from drying out and it will kill the poison ivy vine for sure.
Do not burn any part of the poison ivy...leaves, vine...nothing. If the smoke gets into your lungs with the chemical thats airborne you will be in the hospital.
Good luck......
r payne
>On the bats, if it is determined they are a protected species you can legally leave them alone. That's it, if you try to move them or cut off their access you could be in for a big legal hassel.
ron
Moth Balls
Hank Knight in SC
>We've had luck running bats off with moth balls. My neighbor shot them into his closed-off attic through the ventilation louvers with a slingshot and the bats left promptly. Cheap and effective.
As for the poison ivy, I second the Round Up suggestion.
Tread lightly
Lee Schierer - McKean, PA
>You need to proceed cautiously. There are several species of bats. Some are endangered and several are protected. Disturbing a brooding colony can bring hefty fines. Bats also migrate once it gets cold, so if you can wait, they will leave in late fall. That is the time to seal their opening. They can get in through a very small crack (1/4") and will not readily leave if they have young.
Bats are also very very beneficial. They literally eat tons of insects every year. Your night time insect populations will increase if the bats decrease.
Lee
Strobe Light
CJ McLaughlin
>I recently saw an episode of Ask This Old House in which they showed how a strobe light used to chase critters out of an attic. This obviously isn't going to be 100% effective, but could help chase away some of them and it has the benefit of not be poisonous or destructive.
CJ
Bats also migrate once it gets cold........
>....not true of all species Lee. Some will just hibernate deep in a houses attic or interior till spring comes.
Seversl ears ago I awoke one very cold January nite to our cats collar bell as it tried to follow a little brown bat flying in circles above the wife and I at 1:30 am. Somehow this bat awoke from its hibernation and decided to take flying lessons at our expense.
Ive also heard them above my shop ceiling crawling around since I have a furnace out there that was to their liking.
Thanks guys for all the suggestions
>I'm pretty sure that these bats are just the common brown variety. We get one in the house from time to time. I certainly don't want to run them off completely or do anything harmful to them. I'd just like them to relocate about 40' in one direction or the other.
I'll try the roundup on the roots of the poison ivy and see what happens.
Thanks again for all the contributions,
Gary
