Router technique questions
Doug in Denver
>If using a router free hand to do an edge profile, you move the router from left to right. But what about if you are using a plunge router in the middle of a board to cut a dado across the grain? Still left to right or does it not matter? Also, if using a straightedege to guide the router while cutting dados across the grain, is the strightedge above or below the router? In other words, does having the strightedge on one side of the router or another cause the bit rotation to make the router "hug" the straightedge as opposed to floating away from it?
Re: Router technique questions
Re: Router technique questions *LINK*
Rick Christopherson
>When ever you feed the router, you always pay attention to which direction the bit is going to pull the router. This is determined by the rotation at the leading edge of the cut. You want the bit to pull the router tighter into what ever type of guide system is being employed.
All of the questions you asked are addressed in the Festool OF1400 router manual in more detail than I can go into in this response. There is a section on how to operate a router that is applicable to all routers (that's where this graphic came from). See the link below.
Festool OF1400 Router Manual (pdf)
Router feed direction
Bill Hylton
>When you use a router hand-held, the bit spins clockwise. That means the router itself will tend to veer counterclockwise as you move it.
So...
If you plunge the bit and push the router away from you--no guide involved--it will veer to your left. If you pull to toward you, it will veer to your right. Position the straightedge where the router will veer against it.
*If you are going to push the router away to make the cut, place the straightedge on the left. (If you use an edge guide, place it on the right, so the cutting action will pull it against the workpiece's right edge.)
*If you are going to pull the router toward you to make the cut, place the straightedge on the right. (If you use an edge guide, place it on the left, so the cutting action will pull it against the workpiece's left edge.)
Cutting side to side, as you describe, move the router from your left to your right if it is between you and the straightedge. If the straightedge is between you and the router, the feed direction reverses, that is, from your right to your left.
Just try cutting a scrap piece of plywood without a guide and see what happens. Then cut the plywood using a guide.
Rout safely.
Bill
