OT- Screen display distorts?
Jess Bunch
>I have the XP pro running and for the past few days the JPEG and other picture files do not appear on my screen without distortion. The prints/pictures appear ghostly .. kind-a like looking at a 3D movie w/o the red and green glasses. Hard for this ol' man to focus on. Thank you for any suggestions. Jess
Re: OT- Screen display distorts?
Curly Smith
>I assume you checked for a loose connection?
Do you have a bunch of stuff around the monitor that wasn't there before? I'm assuming no. If that assumption is wrong then you should move the stuff, particularly metal stuff, away from the monitor.
If the problem just happened you should take a look at your driver history. It's possible that XP downloaded a video driver that's not really compatible with your system. You can go to Windows Update from your task bar and review the installation history. Alternatively, or perhaps in addition, visit the PC's makers website and download and install any updates for the video card or monitor. FWIW, Windows wants to install a modem driver on my system that's completely incompatible with the system. It's not a bug though, it's a feature. If this is the problem you need to manually start Windows Update, have it check your system for updates, click on the video update and select the option that amounts to "never show this update again". Future update sessions will then ignore the video update.
If you still have a problem...
Is the distortion just on jpegs or is it just more noticeable with jpegs? If just with jpegs, does your jpeg viewer operate at a different resolution than normal?
It could be a software problem, as I'm hinting at above. The software may be asking your monitor to operate at a frequency it doesn't particularly like. Make sure you have the right monitor selected in device manager and that you're not using a default monitor.
Some monitors have a degauss feature. See if one of the controls on the front brings up a menu and, if so, if degauss is an option somewhere. You might need to refer to your manual or make an internet search on your specific monitor.
It could be that your monitor or video card is failing. My experience suggests the video card.
Lastly, to be consistent with the forum rules, get a Mac
John McGaw
>Does this happen in any particular program or in all programs? Any chance you (or someone else) might have changed the system's display properties, reducing the number of colors displayable to 256 or something like that?
Jess Bunch
>Thanks for the help .. think it fixed it. Jess
