Totally OT for airplane lovers *LINK*
Dan Donaldson
>Don't go here if you don't have a high speed connection. The link is to a video os a short take off and landing in an Alaskan bush pilot competition.
STOL
Dan Donaldson
STOL
That's really impressive! Thanks!
David Sparks
Re: Totally OT for airplane lovers
Larry Clinton At Frankfort (Central)., Indiana
>Don that is impressive. However I have seen shorter (however they were assisted) landings. In the early 60's there were several "paper pipers" at the Lake Village Indiana airport. On one occasion, I was having a cup of coffee and we looked out to see a Piper under power about 3 foot off the ground trying to land - The wind was blowing quite hard and the plane actually was going backward part of the time, hovering at near the same height. A few guys took pity and went out on the sod strip, they grabbed the wingtips, pulled him to the ground. Then they pulled the plane over to the tiedown's and lashed it down. It really wasn't rare to see the Pipers "flying" off the ground when improperly tied down. They really were powered kites.
>They were wonderful machines, Larry. I spent every Saturday and Sunday of my high school years at a local airport. We had a J-3, and a PA-18 later on. That PA-18 could "get up and go". I wonder whatever became of it. It was sold in the late '50s. I think my all time favorite was an old Aeronca L-16 which was on loan to us from the USAF. It was basically a Champion with an 85 hp engine, and plexi over top of the fuselage and half way back. Fun to do Lazy 8's in that.
George
Rod Peterson -- Ormond Beach
George, there's a database somewhere on the net which has all the N numbers the FAA has registered. Shouldn't be hard to find with a search. If you remember the N number of that Pacer there's a good possibility you can track it down. I did that with the C150 my dad had back in the '70s.
Rod
http://registry.faa.gov/aircraftinquiry/
Ells in Boulder
N275T, Roger and Out.
By the way…
>…that registry may not help you if the A/C has been re-registered, and almost certainly won't if N275T has been reassigned to another A/C.
Incidentally, I never said “out” to anyone in 30 years of ATC. I think I only ever heard one guy (out of hundreds—maybe thousands I worked with) say it with even some regularity, and he sounded goofy saying it (he was goofy, now that I reflect on it). It just seemed more efficient to me to go on with my next clearance by addressing it to the flight for which it was intended, which is what the phraseology standard is anyway.
And one of my movie/TV pet peeves is whenever someone says “over and out.” If one is going to be out the phrase over is meaningless, since it indicates an expectation of a response. If one is truly out, then the response will obviously fall on deaf ears.
More than you wanted to know, eh, George? Sorry—once I'm started, it's hard to stop.
Rod
Re: Hey Rod--while we're picking your brain
Henry Higginbotham
>Take a look on Google Earth at the El Paso International Airport. Along the south edge, just north of Boeing Drive, there sits what appears to be a four-engine jet.
But the wingspan measures only 60 feet or so. Too small for even a 146 and it's a low-wing to boot. Any idea what it is? Am I looking at something wrong?
Sometimes you can see some odd things on Google Earth. At the Atlanta airport, there's a plane following another WAY too closely approaching the south runway. Looking closer, it's the same plane, apparently caught in consecutive aerial photos.
I'll have to look at that next week…
>My current computer doesn't have the horsepower to use Google Earth. But a new Dell is on the way and should be online soon.
One of the two Constitutions ever built was at OPF (Opa-Locka, FL—suburb of Miami—the other one was at LAS, I believe) for years, but the last time I drove around there (and the first time in about 30 years) I couldn't find it. However, I barely found the airport at all, and they had really changed the layout. It was hardly recognizable and I flew out of there almost daily for eighteen months in the late '60s.
Another interesting one was the KC-97 at the old Don-Q Inn at Dodgeville, Wisconsin. They flew it in there, but it must have really been exciting. It was definitely a one time operation—they wouldn't be able to fly it out, I don't believe. I think Don-Q is closed, but I don't know what happened to the '97. We only were there the one time.
Rod
McDonnell Douglas 220
Re: McDonnell Douglas 220
Henry Higginbotham
>Thanks, Clint! I doubt I'd ever have found it on my own. I gather from the info Google provided me that the plane now sitting at El Paso is the only McDonnell 220 ever built, had a 58-foot wingspan, and was a prototype for a military contract competition that McDonnell lost to Lockheed. Quite an interesting aircraft.
