Warped Sanding Bed
Warped Sanding Bed
Warped Sanding Bed
Tomm
>The bed on my 6" x 48" stationary disc/belt sander is not flat. It dishes in about 1/32" in the center. I do not know if it was caused by wear or it has always been warped. It appears to be made of cast iron. Is there a way to flatten the bed or do I need to take it to a machine shop? Thanks for your help.
Re: Warped Sanding Bed
Probably just the casting relaxing...
John in New Mexico
>Even old castings can do that, so its probably not wear (the worn beds on various machines I've seen usually leave little doubt as to the cause, and it'd take years of heavy use). Depending on how the bed is mounted and the shape of deformation, you might be able to use shims to counter it. Otherwise if you notice errors induced from the deformed bed, you'd have to get it re-ground, or find another method of working that would minimize those errors.
John
