THE WOODRAT IS BACK!
Connection question...
>I am making a stand for a very heavy dry erase board. The dry erase board is heavy as it is a laminate of 2 pieces of "shower board" and 1/4" plywood in an oak frame.
So, my first attempt at a stand didn't quite work. I am now connecting the two uprights with oak 2 x 2s (as opposed to 1 x 2s and 1 x 4s. I have a "choice" of connecting the uprights to the end grain of the 2 x 2s. I can use a 1/4" bolt and a cross dowel (or barrel) nut or I can use an insert nut that I "hammer" in to the end grain after drilling a suitable hole. I am leaning towards the cross dowel nuts, but I have both on hand.
Re: Connection question...
Must it be knock-down construction?
Ellis Walentine, Host
>If not, why not use through mortise and tenon joints. Much more rack resistant than the barrel bolt idea. If you decide to stick with the KD hardware, the cross-nut solution is the way to go. Threaded inserts will pull out of endgrain.
Re: Must it be knock-down construction?
>I don't have quite enough length on the oak 2 x 2s to do two through tenons. I have enough to do two blind tenons of about 3/4" each. I could do this and the barrel nuts I suppose.
Jesse in New Mexico
>How about floating through tenons?
Jim Dillon
>JL,
If I understand your question, I'm with Jesse on this one by using loose tenons. I'm a big fan of them, especially when I forget to allow enough length for real tenons or have a slightly short board. Double loose tenons might even be better. Can't quite visualize what you are doing, but it sounds like you are connecting two tall upright legs with 2x2 rails (top and bottom) to support your slate at eye level. If so, then some sort of bracing on the lower rail might help with racking, and provide even more support for the heavy slate. Just some thoughts.
Jim
>What I have done is make a framed dry erase board. The dry erase board should be supported so that it will swivel between two uprights. The distance between one end of the frame to the other is 74 1/2". The side uprights are 1 3/4" thick. To do through tenons, I'd have to have boards that are at least 77 1/2" long. I've got two boards that are about 76 1/16" long. So through tenons are not a option :(.
The framed dry erase board is heavy (2 sheets of coated 1/8" shower board, 1 sheet 1/4" plywood and a lot of glue in addition to an oak frame) The framed board is roughly 4' x 6'.
Loose tenons may be an option. I was thinking of blind tenons to minimize the rack and using the barrel nuts to connect it. That way it could be taken apart if necessary. I've used loose tenons before (usually to join aprons to table legs). I could do loose tenons (plunge rout the ends and the uprights). When you suggest double loose tenons, I'm having a hard time picturing them Two 1/4" tenons, separated by 1/2" of material? The ends of my long boards are 1 3/4" square.
TIA
Jim Dillon
>JL,
Yes, you have the concept I was thinking about except you will have to adjust the placement of your loose tenons to the 1 3/4 inch width of your outside legs, and not the 2 x 2 rail. Your suggestion of 1/4 inch wide loose tenons separated by roughly 1/2 inch should work. HOWEVER, this approach means the stand will NOT come apart - which I now understand from rereading your post you would like to do. Hmmm.
You said your slate will pivot. Does this mean the slate is already framed and will then pivot between the two legs? Boy, that seems like a lot of weight to have under control. Two roughly 6 feet long cement boards plus a drafting surface are going to be heavy for sure. This must mean that the weight of the slate will NOT be on the rails per se, but on the pivot point. If that is the case, what about securely attaching a 1 3/4 inch wide brace(s) to the bottom and top rail at each side and then using long connector bolts (like those that are used to connect cabinets together). They can be tightened or loosened with an allen key. This way you won't need to deal with the end grain problem. You could make the bracing kinda decorative to look nice. I still like the idea of some type of bracing to prevent racking of the stand if you move it.
And finally, here's a different approach, but the slate won't pivot. How about building a 3-legged stand like artists use? It could be built to easily support the framed slate and possibly made to fold up as well.
Sorry for the long ramble and I hope this makes a little sense, even if it might not provide a good solution.
Jim
One more thing...
Jim Dillon
>... and that is the length of your loose tenon (if you use that approach). From what you said, it looks like your tenon length in each outside leg can be no more than 1 inch or so. Not a lot to be sure (given the overall dimensions and weight of your project), but you can at least make it 1 1/2 inches wide because of the 2 x 2 dimension of the rail. It might be enough for a permanent arrangement, but - alas - you wanted something more portable 8-(.
Jim
>Why not make tenons on the ends of the horizontal rails about and inch square and 3/8 or a 1/2" long and matching mortises about 5/8 deep in the verticals? Then drill into the center of the end of the tenons and epoxy in a piece of all thread rod sticking out far enough to pass through the verticals and protrude about a 1/2". Then provide four washers knobs that have matching treads. They could match the knobs used to lock the board in place when it is tilted.
You could also provide for angle bracing under the board at the bottom.
