Re: Resawing info?
Curly Smith
>I should have included my reasoning in the post:
I have serious doubts that you'll be able to find somebody to cost effectively resaw your wood. Of course with the chunk of wood you're talking about, cost effective is a very relative term.
Your hesitation in doing the job yourself stems, quite naturally, from the high cost of the wood. A mistake could be very costly but it might not cost more than outsourcing the job. After all, you're not going to ruin the entire slab with a mistake. Do you have a copy of the Duginski bandsaw book and have you setup your bandsaw along his recommendations? With a properly tuned bandsaw, the right TPI blade, and some patience I'm sure you'd do fine. Practice on some 2x12's until you're comfortable and the cuts are accurate.
FWIW, my resawing errors arise primarily from a feed rate that's too high.
