Cleaning rubber rollers
jeff
>Hi all
Quick question.
I need to clean off the pressure rollers on my sander.
Is alcohol ok, or will it attack the rubber.
If not, what should I use?
Jeff
jeff
>Hi all
Quick question.
Jeff
Denatured alcohol.
Hoa Dinh in Alameda
Re: Bleach White tire cleaner
Chuck Lenz
Re: Cleaning rubber rollers
Jim Dillon
>Jeff,
Give isopropyl alcohol "rubbing alcohol" a try. It is available at your local drug store, large grocery store etc.
Jim
Re: Cleaning rubber rollers *LINK*
Phil Thien
>Typewriter platen cleaner. Also available from places that do copier/laser printer repair. The stuff I use is called Fedron. It contains: xylol, ethyl acetate, methanol, ethanol, hexone, aliphatic naphtha, water, and compound oil.
I put a little on a rag, rub it on the rubber parts, and they regain their former soft rubberness. Sometimes I have to do this a few times to a machine that has been neglected for a while.
Fedron link
Mail order suggestions?
jeff
>Any idea where to mail order.
In Vermont, nothing is available!!!
Jeff
Cancel that, found it on Google
jeff
Re: Mail order suggestions?
Howard Norman-Prescott, AZ
>Jeff, you didn't say what you need to order. However, for power tools I have found Amazon to usually have the best price. For hand tools, etc my first choice is Lee Valley. I usually buy screws from McFeeley and have bought a few tools from them also.
All three of the above are online.
Howard
jeff
>Howard
Thank you for the suggestions.
I do use all of them.
This was for a special rubber cleaner, and I found it with the Google search engine.
Jeff
