OT Refinishing prefinished oak floor questions
>Years ago I installed prefinished Vee grooved oak flooring in my dining room. At the door to the deck, the finish wore through in short order. I was taken unawares. I thought the finish was some sort of indestructible type[e stuff and failed to realize the finish had failed. I am now facing refinishing the flooring. It is stained some sort of cherry color. The failure ticked me off so badly I have allowed the floor to wear severely.
Now the question. Is the only thing to do to sand the flooring down past the vee grooves? I can't think of anything else. Otherwise, how would you clean the grooves well enough to put a proper finish on it? OTOH, I hate sanding away that much of the wood. What�s a home owner to do?
Re: OT Refinishing prefinished oak floor questions
r payne
>I don't know exactly what you have but most of the modern prefinished flooring has a veneer surface that won't take much if any sanding and is intended to be replaced when the finish wears through.
ron
Not necessarily so.
Jason Roehl in Mulberry, IN
>What you are referring to is "engineered hardwood flooring", which, to my knowledge is always prefinished. It is essentially plywood. However, there is quite a bit of 3/4" and 3/8" thick solid hardwood sold prefinished.
Unfortunately, Barry, sanding past the v-groove is quite a bit more sanding than you may think. Not that it can't be done, but it would take quite some time and quite a few belts. You'd probably have to start with 12 or 24-grit (I'm not kidding here). As for cleaning out v-grooves, it can be done by hand with a scraper. This too will take some time, but with a good scraper, a file and some stick-to-it-iveness, you'll be done before you know it. After all, that finish wasn't very durable. What scraper to use? Well, I'd go one of two ways. One option is a 2" or 2.5" carbide paint scraper. You won't be able to sharpen this, but unless you hit a nail with it, you won't need to. The downside is that you would only be able to scrape one side of the groove at a time. The other option is a profile scraper made of HSS. I have one that came with 6 (?) different two-ended blades and a file that is held in the handle by a magnet. It looks cheap, but it saved my butt on a 150-year old house's exterior I painted last fall. A few swipes with the file every few minutes easily keeps it sharp. I can't for the life of me remember the brand, though. I do remember I bought it at a Sherwin-Williams store.
If you stain the floor to match the original (or close), the grooves become less important to get fully scraped. Using the edger without going through the grooves is probably the trickiest part of the deal.
Jason (I paint, sand floors and do a little trim carpentry to put food on the table and gas in the tank).
More Info:
>I should have been more clear. It is 3/4" solid oak flooring. It was stained and prefinished. I wish I had realized how poor the finish was. I would have screened it and applied a couple of coats of good finish when I put it down.
I just occurred to me that the stain is on the edges also, so even if I sand the vee grooves away I suspect I will have tiny little stripes across the floor as every joint unless I stain it again.
Can I apply the finish and avoid it pooling or filling the grooves if I leave them?
Ray - SW Ohio
>That is alot of sanding. Is the floor that bad that you couldn't sand the finish off and reapply? Why would you want to sand it down to get rid of the vee groove? Before I would do that much sanding, I would consider replacing the floor in that room.
I have Bruce hardwood flooring throughout my house and it has the vee goove. It does come with a very good warranty, like 15 years. How old is the flooring and who made it? My 2�.
>Its Bruce flooring. They refused to do anything about the finish. Said it was not warranted for such a high trafic area. The finish wore throguh in about six months at the door to the deck. I have kept an area rug over it and it has been a long time. In the mean time an errant nail in a chair leg has put a severe scratch in the finish and there is general wear. I should have hammered Bruce for better service. The best they were going to do was give me new flooring. Installed the floor myself and had no desire to do the work of replacing it. The install is still fine, not a sqeak in an area 14 X 15'. Lots of grooves to contend with though.
I don't really want to sand away the vee grooves, but I can't figure an easy way to clean the grooves or to put the finish on so that it woud not pool in the cracks.
Re: Finish pooling in the grooves
Paul Dwight
>I would think you could largely avoid having the finish pool in the grooves if you brush the finish on. It would be more work and probably take more coats, since each coat would be thinner. In a 14'x15' room, though, it's probably do-able.
Good luck! -- Paul
make it a feature, not a problem
Curly Smith
>It seems to me that you've only got a few options:
- try to remove the stain and refinish the damaged area only
here are some links for removing stains in wood floors (the only one I've ever used in the 50/50 solution of bleach/water)
Spot Cleaning Stains on Wood Floors
Removing Stains from Wood
if you're successful in removing the stain then you'll be left with the task of matching the color when you refinish the area.
- replace the damaged area. Sounds easy enough, good luck on matching the color of the patch with the rest of the room
- sand entire floor and refinish in darker color if you can't remove the stain, same lighter color if you replaced the damaged area
- a runner strip of carpet. Evidently your warranty is for 15 years or until the floor is walked on, whichever comes first.
- a bonus solution if you can't remove the stain: remove a rectangular area, frame it, and then inset new flooring in a herringbone pattern (or a simple diagonal if a herringbone is too busy), or you could use tile/stone. Make it a feature instead of a problem.
I'd try to remove the spot stain first, if that didn't work I'd probably try the entry way feature.
FYI - I think you're overly worried about the finish pooling in the grooves. If you use a lambs wool applicator and thin coats it shouldn't be a problem. Remember, floors are finished and refinished every day.
