Fisheye eliminator
Fisheye eliminator
Fisheye eliminator
Al Stokka - Cambridge, Iowa
>In his book Great Wood Finishes Jeff Jewitt mentions "fisheye eliminator to avoid, obvoiusly, fisheyes.
What is fisheye eliminator?
Does it work?
What company make it?
How is it used? Mix into finish material? Undercoat?
Why do I want to know? Have a pair of end tables on which the finsh wore off. The owner, aparently, used a silicone-containing wax. Owner asked me to refinish the tables and I've been fighting fisheyes for two weeks. Tried Michael Dresdner's method to remove the silicone from the bare-wood areas with less than acceptable results.
Al
Re: Fisheye eliminator
>Not sure if there is what you seek, Al, but what I have done in the past in this situation is to solvent off the piece, sand to end-grit and then apply 2 careful coats of freshly mixed dewaxed shellac. The shellac will act as a barrier to seal in any remaining silicone and separate it from the top coat.
mm
some answers
Bill Tindal, E.TN
>What is fisheye eliminator? I think it is a surfactant, maybe a silicone, and its purpose is to modify the surface tension of the finish so that it "wets" the areas where silicones are present on the wood. Differences in surface tension between a liquid and a surface is what makes water bead up on a waxed car, or fish eyes.
Does it work? Yes
What company make it? I got mine from Mohawk Finishing products but now they have a huge minimum order requirement. Might try Klingspor or Woodcraft..
How is it used? Mix into finish material? A few drops are added to the finish to be applied.
I've been fighting fisheyes for two weeks. The reason I have this stuff is that I was refinishing some doors that had been waxed. I stripped them and sanded them and still got fish eyes, but not after I added the eliminator.
Curly Smith
>You can find various brands of "fisheye eliminators" in an autobody supply shop. If they sell paint, they'll sell a "fisheye eliminator". As an example:
Sherwin Williams W20 - SILAWAY FISHEYE ELIMINATOR
Don't worry, you can get smaller quantities...
Rusty
>Yes it does work.You can get it from an Auto paint store.Works by lowering the surface tension .If you sanded the piece first the silicon gets imbedded in the wood.The stuff I had you just added a few drops per liter.Always better to get the work clean first.
Compatible?
>With waterborne finishes? I use Target Ultra lacquer and Fuhr products, so I'd like to hear about any actual experiences with those finishes.
mm
Steve Schoene
>Yes, it does work, but in that respect it is similar to "the hair of the dog that bit you". That is: it typically contains silicone or the like, which is the likely culprit in the first place. Once you add the fisheye eliminator to the finish you risk contaminating the gun, finish hoses, and the workplace, so that you could have a devil of a time getting back to spraying without having to add fisheye eliminator.
Best try other solutions first. Misting on a very dry coat or two, that don't gave the finish a chance to flow away from the "slick spots" is often recommended. After these coats, you can level with a full coat.
Howard Acheson
>Fisheye eliminator is basically silicone. It works by turning the whole finish into sort of one big fisheye so the finish flows out flat.
As Steve said, the problem is that it contaminates all your spray equipment and anything the overspray gets on. A friend used it in his garage and ended up with problems on all the wood he had stored.
The way we dealt with silicone contamination was to wipe off the surface twice with acetone using a fresh face on the paper wiper for each stroke. We did it twice. Then we sprayed two coats of a 2# cut of dewaxed shellac. Do not sand. Then apply your normal finish. I don't recall a situation where this did not work.
Re: Shellac PS
>When using dewaxed shellac as a barrier coat under waterborne finishes, be sure that your shellac is "fresh." I had to redo the arms on the Lady's Mission chair I posted here when the shellac under the waterborne lacquer fissured like an antique. When I contacted Target Coatings the owner informed me that they have had trouble with such cracking when the shellac is older, especially with SealCoat that's further alone on its 2-year lifespan. He recommended that only freshly mixed shellac be used as a barrier coating under any waterborne finish, and allow the shellac to dry for at least 24 hours before topcoating.
mm
Re: FOLLOWUP
>Holy crap! I'm not about to introduce more silicone to this hassle!
I was hoping to improve my finishing results on the second table (same condition as the first).
My solution, bad as it was, was to spray a light coat of lacquer (aerosol, noy my sprayer), let it dry, wipe down with minerals spirits, wash with ammonia & water, then brush a coat of shellac. Then, alternate lacquer and shellac coats. After I build up a few coats of finsih, I sanded out most of the rings/crater rims produced by the fisheyes, sprayed on a final coat of lacquer and am now waiting for the thing to dry enough to rub out the finish. Hopefully, I can complete the rub-out (to a satin finish) without producing witness lines.
This has produced a reasonably flat finish, I hope. Looks good so far. The rub-out will tell the tale.
For the second table, I think I'll slosh on more mineral spirits (to the point of run off and make a point to wipe only with a clean paper towel. Same process with the ammoinia water. Slosh it on, let it run off and use a paper towel only once.
Thanks (but no thanks on adding more silicone) to all who responded.
Al
Re: FOLLOWUP
Howard Acheson
Why the ammonia water? Ammonia is not a solvent for silicone but it is a solvent for shellac. It can cause problems if there is any ammonia residue left in the wood.
Mineral spirits is not the best chemical to use to remove the silicone. Acetone or lacquer thinner is more effective.
Re: Reason for ammonia water use.
>Howard,
My silicone removal method came from a post, here, by Michael Dresdner on or about April 12, 2007 in which he wrote:
"The solvent for silicone oil is mineral spirits. Scrub contaminated raw wood with liberal amounts of mineral spirits and sop up as much as possible (don't just spread it around.) Follow that with a scrub of liberal amounts of warm water laced with household ammonia, which is a surfactant for silicone oil. Again, mop up as much as possible. This one-two punch will remove the lion's share of the silicone oil."
I don't recall, specifically, but I must have lucked out and not used the ammonia/water on a shellac layer.
I do appreciate you reminding me that ammonia is a solvent for shellac. I'll keep that knowledge in mind when I attack the second table.
Al
How ammonia works, or might work
Bill Tindal, E.TN
>Silicones are chemically destroyed (broken down and turned into something water soluble) by strong base. So, lye would destroy a thin film of silicone pronto. I once had to do it on an auto windshield after using a silicone wiper blade, but that is another tale....
Ammonia is not a surfactant, but it is a weak base and it might similarly attack the silicones. I think it is too weak a base to do much but the proof is in the pudding. If someone has shown that it works with a reliable experiment then I would accept the results. It didn't do much for removing the silicone from my windshield. Personally I think TSP, trisodium phosphate, would be a better choice. However, basic substances can also alter the color of some woods.
I am baffled as to why you are unwilling to use the accepted cure, the fish eye additive. When you are all done try a couple of drops and see how easy it might have been to cure the problem.
Re: Reluctance...
Bill,
Uncertanty is the main reason. Contamination is another. I am using aerosol lacquer, so would have to use the fisheye eliminator with shellac. That means my shellac (small amount) would be contaminated with silicone as well as a somewhat expensive brush that would then not be useable for any other finishing.
You see, these two tables were built by my now-deceased father. I'm not comfortable experimenting on them. If they weren't made by my father, the simple solution would be to make new tops.
I appreciate all the advice and information and will look into using the fisheye eliminator.
Al
