Buying a table saw "link" *LINK*
Rusty
>Thinking of buying a RIDGID 10 In. Cast Iron Table Saw.All of the info I can find on it seems positive.It's on sale for 599.00.
Ridgid Tablesaw
Re: Buying a table saw "link" *LINK*
>I know almost nothing about this saw. My cousin bought one several years ago becasue I said I saw it at HD and it looked good. This was an early model and there was some problem with the shaft. It had a slot in it that would allow chippers in a dado set to slip out of alignment, I think. But based on info I learned here at WC, I sent my cousin in the right direction and Rigid made good on the shaft. I assume Rigid has corrected thge design by now, but it wouldn't hurt to double check. No complaints from the cousin, but I could ask if you want more info.
pecker
>More users of this saw can be found at the woodworking forums here:
http://www.ridgidforum.com/forum/index.php
The price seems high, as the regular price was $549 a month ago, and they were also having a $75 off sale at the time, for a $474 total.
You get a lot for the money, but I have mixed feelings so far about mine. But I haven't used it a lot yet.
I am not sure about the fence... *LINK*
Grant Smith
>The fence looks a lot like the one that was original on my Craftsman saw. The the fence was a bad design, IMHO. Here's why:
If the fence is like I suspect it may be, then it is clamped down from the rear rail to the front rail. Look for a "gripping action" at the rear of the fence. While this may seem like a positive, and indeed results in a VERY stable fence when locked, it also means that the fence will rarely be truly parallel to the blade when locked. If it is the gripping design between the front and rear of the saw, then a great potential exists for it to be very unparallel to the blade at any given time. This is at best innacurate, resulting in burning of stock ripped or wider crosscuts. At worst, it can result in an unsafe pinch situation and thereby cause a kickback and possible injury. On the Craftsman saw I had with that type fence, I replaced it with a Biesmeyer home shop fence and it was like a new saw. Cutting went from a frustrating, smoky, inaccurate event to a repeatable, accurate pleasure.
If, on the other hand the fence is a true T-square type that locks only at the front rail, then it looks like a nice setup for the money. If it has the front to rear locking fence, then be wary of it. The venerable Rigid warranty doesn't resolve a crappy fence design.
If you don't have a table saw, and have a limited budget(who doesn't?), then try to find a second hand saw with a Biesemeyer type fence, or at least a true T-square fence that locks only at the front rail. Grizzly offers a contractors saw that has this type of fence for similar money, shown at the below link (and I am usually not a Griz fan). I suspect you can find similar offerings from Jet and Delta with a good fence.
Or, you'd be far better off buying a $300 list price Biesemeyer fence at your local delta dealer and then finding a $100 old cast iron saw in the classifieds to install it on, with money left over for a link belt, machined pulleys, and a nice blade.
Just remember the mantra: The saw makes the cut, but the fence determines where and how accurately the cut is made.
FWIW,
Grant in Iowa
griz g0575
Re: table saw Thank you
Rusty
>Thanks Guys checking that link out
Re: I am not sure about the fence...
pecker
>The fence doesn't have the issues you describe. While it doesn't operate in the same manner as a Bies, it sets up very square...to within a few thousandths, and can be adjusted easily if need be. The rear clamp just gives it some extra locking power to prevent any movement.
You just missed on the deal...
Denis Ch�nard, Orl�ans, Ont.
>Last weekend it was off another 20% to $479.
That saw came out on top in some magazine review (I think it was Wood) a couple years ago. The arbor shaft issue is supposed to have been resolved.
I looked long and hard at it, but in the end I can't fit it in my shop. I actually sold my contractors saw because of the space issue, and haven't found a way to squeeze another full size saw in the shop. Bummer...
DC
dave in washington
>Rusty, I bought the saw and have used it extensively for the year that I've owned it. No complaints except that it's a little hard getting used to a left tilt blade. Plenty of power, straight cuts and heavy for a contractor's saw. Putting it together was an experience, especially the foot operated elevating device that makes it real easy to move around.
