Sanding sealer
Nick Gibbs
>Which is better, shellac or cellulose (lacquer) based sanding sealer? I am using it under wax.
Thanks
Nick
Sanding sealer
Nick Gibbs
Thanks
Nick
Re: Sanding sealer
Mark Chaimberg
>The type of sanding sealer will depend on the solvent in the wax. If the wax contains any alcohol, the shellac will dissolve upon application of the wax. If the wax contains any acetone, the lacquer will dissolve upon application of the wax.
Re: Sanding sealer
Glenn Madsen near San Francisco
>How do you want to apply your sealer? I pad my shellac on furniture all of the time. Then it gets an application or two of Liberon or Briwax, with synthetic steel wool. Works pretty well.
Spraying lacquer sealers and finishes is something I don't do. Yet.
Whatcha makin?
I'm baffled
Bill Tindal, E.TN
>There is sanding sealer, a material that must be covered by a real finish and there is shellac, a finish, that like many finishes, can be sanded. What are you trying to accomplish?
Shellac plus wax is fine. True sanding sealer plus just wax is a bad idea for a host of reasons.
