Sizing Wood
Sizing Wood
Sizing Wood
Bill Christian
>I am retired and new to woodworking. I ordered some plans and the materials list for the lumber uses terms like 12/4 x 6 Cypress, 6/4 x 6 and 5/4 x 6. I understand the species of wood but what do these sizes represent in English? Is there a chart available to help me out?
Thanks, Bill
Re: Sizing Wood
Re: Sizing Wood
>Common sizing of rough (unmilled lumber) is designated as "quarters" (as in quarters of an inch) and is usually: 12/4 , 8/4 , 6/4 , 5/4 and 4/4
so
12/4 = is about 3" thick
6/4 = is about 1-1/2" thick
5/4 = is about 1-1/4" thick
and then x 6 = 6" wide
Usually when talking about rough wood we use these sizes. After preparing the stock with a joitner and planer the thickness becomes smaller, obviously, and we measure in inches.
So 4/4 after preparation might be around 3/4", and 5/4 might be around 1". And if plans call for 3/4" you'll have to start with 4/4.
Of course if you're like me you'll start off with 8/4 and end up with wood that's 3/4" thick and WAY TOO MUCH shavinging on the floro and dust collector.
Happy Woodworking!
Re: Sizing Wood
Re: Sizing Wood *LINK*
Kris Lasure
>Bill -
Here is a chart to easily understand how to measure board feet and convert quarters over to dimensions.
Welcome to woodworking!!
Kris
http://http://www.integritywoodproducts.com/bfchart.pdf
Re: Sizing Wood
ALso depends where you shop
>Go to a lumber mill that sells rough wood, or even partialyl planed wood, and you'll see they sell 4/4, 6/4, 8/4 lumber.
Go to Homedepot and you'll see they sell 3/4" wood.
It's a little like a 2x4 stud, we all know that a 2x4 stud supposed started out a 2" x 4" but the studs we buy at HomeDepot measure less than than.
ALso a little like a 1/4 Pounder or BigMac at McDonalds. That's 1/4 pound all beef as measured before it's cooked ;)
Happy Woodworking!
Re: Sizing Wood
Re: Sizing Wood
mdclor
>Welcome! You will also see wood listed as S2S or S4S which means that 2 sides have been surfaced (or planed) or all 4 sides have been planed. Wood purchased at the Borg is S4S and therefore 0.75", for example, whereas if you purchase it in the rough, it will be 4/4 or 1 inch.
You have a great learning curve to climb, then comes the slippery slope of purchasing the newest, latest, greatest, fastest machinery. It is all fun. ;^)
Merle
Re: Sizing Wood
Yep, I know what you mean.
Basil
>And no matter how many times I run it thru the planer it still comes out to thin.
Re: Sizing Wood
One other thing
Dan Donaldson
>If you get the ability to surface plane your own wood, you can buy the rough lumber and usually get it thicker than already processed. For example, if you buy a piece of 4/4 at the borg, it will be 3/4 thick. If you buy it in the rough and do it yourself, you can usually get it to come out somewhere around 7/8 to 15/16ths. That bit of extra thickness can add a lot to a project.
Re: Sizing Wood
Possibly a bit more confusion!
Lee Schierer - McKean, PA
>The explanations of the quarter system for wood measurement are all good adn relate to rough lumber or lumber from a mill.
There is also a system for dimensioned lumber that says 1 X 4 which in reality will be 3/4 x 3-1/2 in actual size and is generall sold by the lineal foot or by fixed lengths of 6, 8, 10, 12, etc foot pieces. This system generally deals with materials commonly used for construction, but can also deal with commercially sold hardwoods.
The designations refer to the raw blank size that was "finished" to make a "dimensioned" piece of lumber.
When buying hardwood. The Borgs should be your source of last resort. Generally speaking you can get better quality material, better selection and significantly lower prices from local hardwood lumber suppliers.
Lee
Re: Sizing Wood
Re: Sizing Wood
Tony - Memphis
>Congratulations on your retirement and your entry into woodworking. Hope you enjoy both!
One other thing to consider is that hardwood dealers don't deal in exact measurements. For example, the S2S wood at my dealer is usually around 13/16. The "4/4" can be anything around 4/4. So, its important to know how your dealer measures and prices and so on. I tend to look at like this...anything in the 4/4 stack is around 4/4 and is whatever price is posted assuming it is all exactly 4/4. Sometimes you get a little over, sometimes a little under. Sometimes they knock off for a defect, sometimes they don't. Different folks at the dealer figure things differently too. Its a bit of a game actually.
Good luck with your project.
Tony
Re: Sizing Wood
Re: ALso depends where you shop
Bill Christian
>Thanks to everyone for your response on sizing lumber. Now I get it.
Re: Sizing Wood
Re: Sizing Wood - Sawmills sure do roundup
Larry Clinton At Frankfort (Central)., Indiana
>The mill I occasionally buy from has a "roundup" policy. They do let you pick the boards you want - but you have to be careful of their markings. It pays to carry a tape measure (I also carry a real small plane to look at some of the wood). They will mark a piece 7/8 to 1 1/4 thick (at the thinnest area) as 4/4 - Width is done the same, if it is 6 5/8 to 7 1/2" wide (at the narrowest point) - it is marked 7. So you can buy a piece 1 1/4" thick X 7 1/2 wide for the same price as a piece 7/8 thick X 6 5/8 wide. These are all rough sawn measurements. It really pays to know what you are buying the wood for - IE: If you are buying wood to make a 4' long top you really need to get flat pieces with good thickness so you can plane a 4' flat board 3/4 thick from them. If you are using short pieces in your project it isn't as important.
