Re: And be sure to...
Steve Schoene
>Ventilation is important with MC paint stripper, it's nasty stuff, but much more effective than the others. I would only work out of doors with MC stripper if I didn't have either a serious mask, rated specifically for MC stripper, and/or really serious ventilation (not just a couple of open windows).
Oil/varnish, such as Watco, where you apply it "wet" and after a short time wipe it off, can look nice. They do require periodic "refreshing", and can be damaged. Only choose these if you and your guests are the kind of folks that always use coasters.
I'm going to suggest that you go with a good traditional resin varnish. Polyurethane (single part consumer grade) is OK, but to my mind the traditional resin varnishes are quite a bit easier to rub out to an even sheen. I don't think the extra toughness of polyurethane varnishes is needed for furniture. Behlen Rockhard is good but a bit dark, and for a lighter finish, Pratt & Lambert 38, or McCloskey Heirloom are also good.
"Full strength" varnish applied with a brush, will give a very protective finish after just a few coats--three perhaps, and is easier to "rub out" to eliminate the inevitable dust nibs.
Wiping varnish, either made by thinning a standard varnish such as listed above, or bought that way, such as Waterlox, are somewhat easier to apply, and since they are thinner, dry enough faster that dust is a smaller problem, though not completely eliminated.
I suggest you get some wood that is similar to the table top, and make some practice finishes on it, to see how different finishes work and how they look. Much better to make mistakes on wood that is already scrap.
