Ceiling Procedures
Ceiling Procedures
Ceiling Procedures
Robert Englebrecht
>I want to cover my existing living room ceiling with T&G Aspen. Currently it has 5/8 textured drywall. Some questions come in mind.
1. Should I install firing(sp?) strips before I install the T&G?
2. What finish should be applied?
3. Should the finish be applied before I hang the T&G?
Any tricks or tips will be appreciated.
Bob
Re: Ceiling Procedures
No to furring, yes to pre-finishing
Ellis Walentine, Host
>With a decent stud finder, you should be able to snap lines on all your ceiling joist centers and avoid the need for furring, but suit yourself. Pre-finishing will save you a world of hassle once the ceiling is installed, not to mention that it will prevent bare wood from showing if/when the boards shrink next winter.
Curly Smith
Depends on which direction the ceiling joists run. If you install perpendicular to the joists then you can nail into them, otherwise you'll need the nailing strips.
I'd go with clear gloss poly but you might prefer a semi-gloss. I'd also apply to both sides.
Yes, it's easier to work on the ground than in the air.
Build a work platform or rent some scaffolding.
Snap lines for the joists if you're nailing into them, make sure your starter course is straight. Try to lay out the boards ahead of time and adjust cuts so you don't get narrow boards in obvious spots (think about it as a tiling job).
Pete LaBelle
>When laying T&G on a wall or ceiling, point the tonges toward the direction where it will be most visible. That way, the groove, which can sometimes develop gaps, will be less visible. This is especially true in the winter when humidity is down and the wood shrinks.
