Another Workbench Question...
Rob Hix - King George, VA
>Hey all,
As the time draws closer to get a good start on my workbench, I have been contemplating more and more what to do about my top. I was considering buying one vs. making one. If I made one was I going to go for a hybrid solid wood and sheet good top or something else. My fear was in flattening the top. Now that I have been reading up on flattening the top with a router jig, I have almost completely decided to build my top. I figure I can build a much thicker top for quite a bit cheaper that I can buy one.
Now for the question. In order to speed things up and get a bench to going I am considering using pine (yes, as in 2x4s) for my top. This will put me a 3"+ thickness. The only problem I see is the obvious warping issue before glue-up, and that I will be able to leave dings in the top. Can anyone give me anything else that should keep me from doing this? I am guessing in a couple of years I will either make a proper maple top, or make another pine one.
Thanks in advance,
Rob Hix
