Preliminary thoughts.
Rod Peterson -- Ormond Beach
>There's no escaping the elegance of the design. I had the same thought as you—why try to split hairs on a 3" diameter scale when you can make the same adjustment by splitting the functional equivalent of quarter inch ropes at an effective diameter of >7". I did a similar thing on my radial arm saw years ago, for the same reason.
The sandpaper-like material they include for the face of the gauge is, in my mind, a little too coarse—seems to be around an 80 grit. I'd have been happier with something on the order of 100 or even 150 grit. It's far too early to tell if that's really an issue, however. It is nice having a grippy miter gauge face for the first time, whatever the grit (of course, I could have glued sandpaper on the 34-895…).
The engineering of the gauge face (movable left and right along the base assembly), the extension (will go in either side of the face for left or right miter slot usage), and the flip stop (works on either the main gauge face or the extension face) I think are nicely done.
It seems plenty robust enough. I think the main complaint I've heard has to do with the sloppy feel when the gauge is extended the full 45° in the long dimension of the strut. Yes, I can feel it, too—there is a bit of rattle in the assembly in that configuration, but actually observing the total motion at the outer edge of the gauge yields a very, very few thousandths (we're talking some 18" away from the blade), and when you interpolate that back to the pivot point, it has to be just a few minutes of an angle. I can't believe (intuitively—I haven't empirically measured it yet on real miter cuts) that it will matter in the real world.
I really think I'm going to like it, however, for repetitive cuts on stock too wide for the miter saw. At least that's at first blush. I'll get around to checking the miter cutting later, although to be fair, that's not why I bought the Osborne—I like cutting my miters on a sled.
And it's nice having a robust, well designed piece of equipment I can depend on. Now I can take the piece of Baltic birch off my 34-895 and stow it back in its slot in the motor cover (possibly never to be used again) thus clearing a little clutter off the top of my storage surface…er, extension table.
More later.
Rod
