Jointer Pushy Blocks
Wayne Carson
>I am making some push blocks for my jointer and need suggestions on what to use for the rubber gripper part.
Wayne Carson
Re: Mouse pad
Larry Clinton At Frankfort (Central)., Indiana
>Many computer mouse pads have foam rubber on the back of the pad that has a pretty good grip. It would be fairly easy to cut one up and try it. The fabric top looks like it would be easy to glue to the wood.
Carpet underlayment
Neal in San Jose
>There's also that stuff they sell for router pads, kinda looks like perforated rubber about an 1/8 thick. I just put some of that in the back of my station wagon on the plastic tray that protects the carpet to keep stuff from sliding around. I used double sided tape to hold it down. Kinda silly, I know, protecting the carpet that didn't have the sliding around problem with something that introduces a problem that needs another layer.
DITTO
Re: Jointer Pushy Blocks
Mike Fitterling
>I've not had the best luck with those rubber bottomed push blocks. The rubber peels back or comes off and usually at the worst time. I now have a 12" jointer and if you've ever tried pushing a 10" plus board through for face planing, you'll know that it takes something with more grip. I made a set of pushblocks myself using some 60 grit sandpaper to cover the bottom, but it would still slip sometimes. So I took those pushblocks (made of 3/4" plywood scrap) and drove drywall screws though them at 45 degree angles so that the tips just protrude. This thing never fails to hold. If I need more grip or the tips wear down you can just put in new screws or drive these in deeper so there are longer "teeth" sticking out. If you can visualize those carpet knee kickers, where they grip the carpet, that is how this looks. Because almost always the lumber having passed through the jointer first, goes on to the planer and other machinery, the little holes the tips leave are not a problem and get planed out later.
One thing you have to remember with these is to lay them down tips up, or you might scratch your jointer table. I suppose you could use brass screws and avoid that possibility.
Cheers,
Mike
If you can handle spending 10-15 bucks.......
Scott in Eastern Iowa
>.....to to your favorite colored Borg and hit the tile section.
Pick up a coupla handled floats used to push grout around. These are at least 3/4" thick semi porous pads with a large handle and a even larger surface.
I found that using the regular sized pads got me a wee bit too close to the spining blades of my DJ 20 and found these to take their place.
My other pads just sit around bored now.......
Re: If you can handle spending 10-15 bucks....... *LINK*
John Quillan
>Spray the bottom with a couple coats of Plasti Dip or you can brush it on as well.
I have used it for push sticks.
http://www.plastidip.com/consumer/index.html
I used a grout float
Chad Pearson
>When I went to a wide jointer last October I immediately realized that it took a lot more force to push a 16" piece of wood over the knives compared to my 6 inch jointer. I grabbed an old grout float and epoxied a small piece of 1/8" wood to the heel of the float.
When I joint a panel I use one of my old rubber bottomed push pads in my left hand and the grout float in my right. The lip of wood epoxied to the back of the float provides just the right catch to push the wood forward.
Attend teh 5 Barns picnic!
Lee Schierer - McKean, PA
>Each year for the past several years there has been a box with scrap pieces of some red silicone rubber material with a self adhesive backing. This material works great for push blocks. Sorry, I can't recall who donates the material. Yet another great reason to attend the picnic, besides good food, good woodworking and friendship.
Lee
Steve Schoene
>I have never understood the foam pads that are to be used to push wood trhough jointers. The problem is that they don't allow the pressure to be on the right places. The downward pressure belongs on the outfeed table, typically a little past the blades. But you don't want downward pressure over the infeed table, the pressure there should be the forward movement. So I use a heavy block with a hook to use for pushing over the infeed, and use a fairly smooth pad that will allow the board to slide under it while it provides the downforce.
