Exterior door question
Andy Halterman: A fine spring day
>Got a fancy set of Mahogany French doors to refinish. The spar varnish on them has given up the solvent based ghost and the client wants them stripped and oiled. No more film finishes they say.
I'm thinking teak oil or something of the like? These doors get sun about half the day on average. More in summer, less in winter. They are fairly faded because of that.
Am I on the right track with my logic or suffering from a lack thereof?
Andy Halterman
It's off to the Monday evening road bike ride in Hendersonville, NC�
Re: Exterior door question
Steve Schoene
>If they want an oil finish they should understand that they need to apply additional finish about every month, yes MONTH or so, forever. I'd probably use Watco Marine oil/varnish mix, which at least has a bit of UV protective additive.
All clear finishes require regular maintenance. Maintenence of oil finishes is easier, but it must be much more frequent if the wood isn't to turn grey. Paint stretches out the maintenance schedule dramatically.
There really insn't any thing as "teak oil"--it's a marketing term for whatever oil or oil/varnish the manufacturer puts in it.
Jesper, Denmark
Jesper, Denmark
>Some of the marine oil finishes, such as Sikkens or Deksolje may be OK. They are usually called Teak-something-or-other because Teak is what is used on boats.
To extend the re-finishing time, the "good" ones have some pigmentation to reduce UV effects - but they also have a masking effect on the wood color and IMHO look fuzzy and artificial.
Just as a comment, I would expect the doors to get more sun in the winter than in summer - any overhang will tend to shadow the doors in summer when the sun is higher.
Charles Sharp
>I have a frame and raised panel garage door that faces south. Over the almost 30 years I've had it, I've tried a lot of products. Currently I'm using Thompson's Water Seal Advanced Natural Wood Protector and it's holding up better than anything I have ever used.
Bill White
>I have just put a finish on a new fir door for our new home. I used a conditioner, stain, glaze, then 5 coats of "Old Masters" clear water-borne poly. Told that it will last longer than spar poly.
Have not hung the door yet. Just waiting to wool and wax before installation.
Bill
Jim Dillon
>Charles,
That's interesting to know as Thompsons sure has a bad rep based on their near water-like product 20+ years ago. Sounds like they have improved it, which is good.
Jim
