Pepper mill
Pepper mill
Pepper mill
Tom Russell
>I could use some help drilling a pepper mill. What kind of bit? Drill first, then turn? Or the other way? I have a dril press, a good lathe, and the metal parts for a pepper mill. TR
Re: Pepper mill
Re: Pepper mill
Paul Waddle
>Hi, I'm not too proficient in lathe work,but I would suggest Partially turning outside,holding it in a chuck and tail stock so you can turn a true round spot at a longer than the finished length that can be held by a ballbearing outside support. I would then use increasingly larger drills in the tail chuck (intially centered at tail stock mark),until I could then use an inside turning tool to finsh.I'm thinking wood or metal bits.
Next while still being supported by the center rest,complete the outside. It should still run true so you can cut the pc to length. pw
