emergency stop for saw
peter kolb
>I own a Jet JTAS-10 cabinet saw and I am not comfortable with the stop button on the starter. The stop button is too hard to find. I need advice. Do I install a mushroom stop button or a paddle type actuator over the existing starter? Alternatives? Thanks for your help Peter in south central NJ
Re: emergency stop for saw
Larry Clinton At Frankfort (Central)., Indiana
>Depends on the motor stop / start circuit. I would imagine that saw has a relay to start the motor. It is very easy to test. Just plug in the saw and start it. While the saw is running, unplug it, then plug it back in. If the saw restarts on its own, it doesn't have a relay. If the saw doesn't restart until you depress the start button it does have a relay.
If it has a relay, you can put a E-stop switch anywhere you want, all you need to do is run a 2 wire cord to the existing stop switch, remove one wire (either wire) from the old STOP switch. You then connect (either) one of the wires from your new switch to the old switch and connect the two loose wires together. The new switch will have to be wired Normally closed (NC). The new switch can be a momentary or two position switch (push in for off - pull out to reset to the run position) If you don't have a relay - it is a little harder as the existing switch will have 2 positions - Off and On - in the on position the switch is closed - off is open. In that case you would wire the new switch as above - but you MUST have a two position stop switch - again wired NC.
Been there, Done that
Neal in San Jose
>I hinged a largish (maybe 6" wide by 8" long) piece of 1/2 birch ply to the bottom of the fence rail in front of the factory start/stop assembly. I drilled a 1 1/2" hole thru the paddle in line with the start button so that starting was easy, but deliberate. I then put a small block of the appropriate size on the back of the paddle that lined up with the stop button so that nudgeing the paddle with my knee turned it off. It worked very well, and when I sold the saw, I think this upgrade convinced the buyer this was the saw for him.
I wish I could claim credit for this, but I got it from Kelley Mehler's book on table saws. HTH
Andy Lincoln,In Dearborn MI
>Peter,
Here is a scan from FWW a few years back.I built a similar unit and installed it on my table saw with some help from a retired electrician friend.
The same idea has been adopted by my employer and we have 10 table saws running and I can't remember the last time we had a table saw accident.
Andy
Over and under
>My Unisaw comes with a fairly good large button below the fence rail that allows me to easily turn off the saw with my leg.
But I also installed a 240V-DPST switch that is attached to my UniGuard (over-arm blade guard). So depending on what's the most convenient and safest, I can turn off the saw by using the switch that is over the table or under the table.
The new switch over the table is wired into the cord, so electricity lfows from the plug to the overarm switch, to the undertable magnetic switch and then the motor.
Happy Woodworking!
E-stop
Lee Schierer - McKean, PA
>A few years back one of the woodworking magazines, (Wood, Popular Woodworking, or Workbench) had an article on adding an emergency stop to a table saw that you could bump with your knee under the table. It was pretty neat how they made a swinging arm arrangement that would turn off the saw by using either knee. Sorry I can't recall exactly which magazine it was.
Lee
Re: emergency stop for saw *LINK*
Denny
>Peter,
Take a look at this website, there's a Jet with a very nice homebrew switch. I'm planning on doing something similar soon...
Denny
Jet Switch
Knee Switch Front View
Jim Rahbe, Bedford, TX
>Peter,
Here is what I did. Looks crude but very effective. The hole in the �paddle� allows you to push the start switch. A slight push with your knee shuts the saw off. I like it because I can easily shut the saw off while keeping both hands on the material, and I don�t have to take my eyes off the blade.
First pic shows the paddle with the start hole�
Second pic is a side view showing the carriage bolt that pushes the off switch and the hinge at the top of the paddle.
Someone here made one out of Plexiglas, which really looks professional.
Jim R.
Knee Switch Side View
Jim DeLaney, Austintown, Ohio
Re: Knee Switch Front View
>Gee, mine looks exactly like that. Did you copy me, or did I copy you?...
I did paint mine red, though.
I've also got similar setups on my 6" jointer, and my 14" bandsaw.
They work very well.
Jim D.
Most Accurate
Hoa Dinh in Alameda
>"Someone here made one out of Plexiglas, which really looks professional."
This?
I don't know about "professional." But since it has the Incra protractor, I can claim it "the most accurate." ;-)
I added one for the router table as well.
-- Hoa
Here's the Incra Protractor
Hoa Dinh in Alameda
Ha,ha.... remind me
>Hoa, Remind me.... why did you use that Incra protractor for this? I think you mentioned it way back in your post, but I can't remember.
Nice!
Happy Woodworking!
Just because...
Hoa Dinh in Alameda
>I have one around and being a woodworker, I don't throw away anything ;-)
I bought an Incra 1000SE. The hole in the protractor was just slightly too large (0.005") for the pivot bolt. Incra (Taylor Design Group) handpicked a new protractor with a matching bolt and sent it to me.
Here's a photo of the miter gauge after the surgery.
-- Hoa
