>Can't say for sure but do know that mortgage companies charge more fees than banks do. I'm talking a couple of grand in extra fees for services that banks do not charge for.
>Sid - Reverse mortgages have been around for almost 40 years now, but have just become common in the last decade. The idea is that a lender, and there are many now, will pay you a monthly income or a lump sum based on the equity in your home. Typically these mortgages are only due upon the sale of the home or the death of the mortgagee, whichever comes first.
The fees charged for these mortgages have come down substantially over the years, but are still steep. After all, they�re pretty risky for the lender.
The amount you would get every month depends on your age, the equity in the home, the amount of any underlying liens and other factors. You typically need to be 62 or older and have your home paid off or have a very small lien.
Are they the right vehicle for you? If you have the need for a steady income, are older, have no heirs you would wish to leave your home equity to and have your home nearly or completely paid for; sure. If you�re looking for a lump sum of cash for a home improvement project, there are better ways.
You might try the National Reverse Mortgage Lenders Association (absolutely no endorsement implied!!) for some more information. A quick Google search for �Reverse Mortgage Lenders� returned over a million sites.
>Hi Sid. One of your problems is listening to AARP. But that is just my opinion....
The reverse mortgage is what the financial people call a "present value problem." The mortgage company will figure the current value of your home and your equity in it. Then based upon your age, or some other magic formula, they will come up with a monthly payment amount based upon the current interest rates. What the mortgage company is asking you is 'would you rather have X dollars equity in your home or would you rather have a series of payments of XX dollars for ZZ years.'
Not being the trusting type(any longer,) I would get a set of numbers from several sources and then take them to a certified public accountant for analysis. You also want to investigate any potential tax liabilities that may come up. Yes, it might cost you a couple hundred to see a CPA, but you can be sure that the deal is for you or not for you.
Remember, the mortgage companies are in business to make money first and foremost.
I am not an accountant, but I have slept in a Holiday Inn.
I've been listening to Clark Howard on AM750 in Atlanta for a while, and very recently (last week as a matter of fact) found and started listening to Dave Ramsey on AM640.
Both very informative guys with good information on these things and most money matters. Clark's show is syndiacted and I imagine Dave's is also, so they should be available in most radio markets in the US. Defintely worth a listen.
>The only reason a money source provides one of these things is to make money. It'll cost you in the long run.
If, as others pointed out, you have no need to maintain the equity in your home (no one to leave it to, etc.), it might make sense to find a means of liquidating that equity for your use until you no longer need it. Check with your accountant. You might be farther ahead to get a fixed-rate mortgage for the bulk of the value and put the lump sum into something like certificates of deposit from which you can extract what you need as needed plus whatever it takes to keep up the payments on the mortgage.
>Unfortunately, the issue isn't just one of present value, though it would reduce to that if you knew exactly when you were going to die. I don't think a CPA has the skills to reach a definative solution, though some, but not nearly all, have good financial sense and can help you understand the issues.
It's a actuarial problem, not too dissimilar to the issues involved when a retirement account is converted into a annuity for life. Numbers for such conversions might provide a entryway into analysing whether a particular reverse mortgage proposal is a rip-off or not. Predicting future real estate values is probably subject to much more variance than estimating future returns from financial instruments.
>I have given this a little thought and absolutely no research. As a Home Inspector, I occasionally get a call to do an inspection on a house subject to a reverse mortgage. The reverse mortgage companies are "interested" in maintaining their equity; that is your house. I have seen them make people do some pretty serious upgrades like dealing with asbestos and lead paint and a new roof. I have also seen them do some pretty petty things like make people change out cracked window panes.
This is a very complex problem. An Actuarial in the sense of how long will YOU live. A Present Value in the sense of what is the value of your house. But to make it even more complicated there are at least two other factors. You have to do the maintenance on your house to maintain the value. Another factor is that the value of your house should be going up with the rest of the real estate market in your area.
So, in the last few years around here, houses doubled in value. So if you started receiving payments based on your house was worth X, what happens to them when your house is worth 2X? Do you have to take part of the payments you receive and Paint and maintain your house to assure the bank gets their equity? Suppose you thought you were going to live another ten years and would receive ten percent of the value of your house a year and that therefore, you would have received most of the value before you die, but you die in one year (a terrible hand plane accident), what happens to the rest of the value. Or the other way around, suppose you live twenty five years instead of ten?
Another thought. Suppose you have a life insurance policy worth Y and its paid up. Why can't you start taking the money now, before you die? This is actually much simpler than the Reverse mortgage. This is just a pool of cash to dip into, has nothing to do with rising property values or home maintenance.
