Follow up on Painting and TSP
>I posted a message here a day or two ago about painting a rental house and cleaning it with TSP. Since the post fell of the bottom and am posting the response I got from Zinsser "at the top".
The place I was trying to paint was grimy. I tried Simple Green and was not happy (Seemed like I was chasing the crud around, but not removing it). On advice from two different paint store and Lowes, I bought and cleaned it with TSP. The real stuff with the Phosphorous. It was stunning. Grime came off to the point I had sediment in the bucket or cleaning water. Was told it did not leave a film behind.
Then I bought Zinsser 1 2 3 primer. Again based on the advice that it was "the real deal" and the best thing going for painting over gloss and dirt and nicotine and whatever. I had washed down the trim and some of the walls, but not the ceilings.
On the label it said "use the appropriate solvent" (Do not use TSP). There was no explanation. The paint store people did not know why. Painters said, "I been using TSP for twenty years, works great" "if it gets washed at all it gets washed with TSP".
This morning I Called Zinsser (not available on the weekend) and there answer was that TSP leaves a residue or film and that the paint won't adhere. That I should have used ammonia and water. The product has some ammonia in it. (Stinks). I suspect the ammonia in the cleaning solution is compatible with the ammonia in the product.
They said that if there were a residue left the failure would be the primer would peel off.
PS, Being the manly man that I am, I had no time to wait on Zinsser to come back from the weekend and I have primed the house. Seems to have worked well. There have been places where I spotted defects under the primer and went back and sanded with a ROS. No problem. That stuff holds on well. The label says it gains bond strength for about 7 days. Should be good to go. Time to move on with this, I hate painting and have had about all I can stand.
