Better adesive for structural exterior wood ?
Pete LaBelle
>Guys -
Working on an exterior project where I need some short heavy timbers and haven't the time to have them sawn & air dried for several years. Timbers will be about 4" x 12" x 4 feet long, and will be glued up from 2" thick planks. Wood is air dried white oak. The glue-up will be getting wet occasionally from splashed or rain water.
Titebond III? Epoxy? Exterior construction adhesive? Something else?
What's your experiences in either stuff that worked, or stuff that didn't ?
Thanx......Pete
Re: Better adesive for structural exterior wood ?
Resorcinol *LINK*
>Read the page linked and bookmark the site for future reference.
mm
Glue
I'd use epoxy
Ellis Walentine, Host
>I have done a lot of exterior wood laminations in the gate business and epoxy is my go-to glue. It will hold just fine on air-dry lumber. Resourcinol glue is a time-honored boatbuilders glue that will also work, but surface preparation is critical. Your glue faces will need to be very flat and in perfect contact to get the most strength from the joint. That means a lot of clamping, too. With epoxy, the mating parts and clamp pressure aren't so important, as epoxy will bridge any gap as long as the glue doesn't run out of it.
2¢ for you,
Thanx !
Pete LaBelle
