Compound Miter Angles?!?.....
durk
>Not exactly 'fine' woodworking - but I'm just about to finish my never-ending back deck project. The final piece is a flared staircase that connects an upper deck to a lower deck. My question is on cutting the compound miter angles for the handrail, etc. Say in this case you were using a a 2x4 for the handrail...if the rail was between posts on a flat ground then a person would just cut the 2x4 to length. Now for stairs at an incline say 35 degrees, a person would lay the 2x4 flat on the miter saw and tilt the blade 35 degrees to make the cut. Now for a flared stairs (that go from 3 feet wide at the top to 5 feet wide at the bottom) - if that flare angle was say 40 degrees...?... would a person tilt the blade 35 and rotate the blade 40 to get the compound angle?!?
I'm sure I'm overthinking this, but is there more to that calculation than this, or do I just have the 'deer in headlights' look because I found the darn (arctan *&!# / 3.1456 *23441* the number of kids in your brothers family= compound miter angle) compound miter calculation formula in the woodcentral articles section? It also could be that I'm an English major :).
Anyway - anyone who could help a guy who only makes square box things would be greatly appreciated!
thanks,
durk
Re: Compound Miter Angles?!?.....
Curly Smith
>Others may disagree but I think you'd have better success with marking the pieces and then cutting instead of trying to calculate the angles. It's rather annoying to cut your 35 degree / 40 degree compound miter and find that it should have been 34 degrees / 40.5 degrees (DAMHIKT).
But, if you want to calculate, try this:
Compound Miter Saw Calulations
