>Well I am strating to get ready to move into my new place. I am trying to figure out what I want to do before I get my stuff in the house and in the way. All the heat ducts are easy to get to and made of tin. I was wondering should I insulate them while I can get to them, would it help? Or should I just do the hot and cold copper pipes and not worry about the heat ducts? I was think foam board to insulate them and tape to hole it togeather.
>My brother lives in Dallas and has the heat/AC ducts in the attic. Before insulating the ductwork he took several bends out of the round duct to increase air flow effeciency. Then he used foil backed blankets made for duct insulation.
He had been monitoring evergy consumption before doing the insulation. Even before getting post insulation energy bills he knew that it had worked because the AC ran less. Before he hardly ever heard the AC turn off. After he noticed when it turned on. After a few months he did the evergy saving calculations and he would get a payback very quickly.
>As mentioned by others, it depends on where the ducts are and to some extent where the house is (what climate)
If the ducts are inside living space, not much need to insulate.
OTOH depending on the climate it could be important. Always baffled me that they put the ducts in attics and put poor or no insulation on them. The hottest and coldest air running inside metal ducts that are poorly insulated????
The insulation can also make the system quieter and eliminate or reduce sweating of the ducts for AC. On AC ducts, the vapor barrier must be on the outside.
Other than the work and expense, there is probably no down side.
Insulating the first fifteen feet of pipe form the water heater usually pays off. If you have well water it may pay to insulate the cold water pipes to stop heat loss in winter, if they are in the living space. Might protect form freezing if you are in a cold climate.
>Broadly speaking (I'm no expert here), any ducts (and perhaps water pipes) in areas of your house that are NOT heated or cooled should be insulated - especially if you live in areas that will get well below freezing in the winter. In our neck of the woods (MD, VA), our AC installers said the supply-side AC ducts in non-airconditioned space (crawl space, attic etc.) are required to be insulated to a particular R value, and that newer code now requires that the return side, if in non-conditioned space, be insulated as well. Of coarse, in areas of the country that have mild weather, the issue of freezing pipes is not of concern. As we get into the warmer weather, here is a link to a forum that I have found to be very useful. My 2 cents.
>Guess I'm of the old school, if the ducts are under the house, I would not insulate them. I would however, insulate the inside of the foundation and spend the time and money insuring you have it well sealed in the winter. You also need to have ventilation in the summer if you have moisture present. I live on a hill and the crawl space of my 1880's home is as dry as a desert, therefore I have the foundation sealed year around. The heating ducts being uninsulated keep my floors warmer and I have no issues with water pipes / drains freezing even when it is 15 below with wind blowing. I also figure if any moist air does get into the crawl space in the summer, the cold ducts will condense the moisture and eliminate any dampness, the ground is extremely dry so any dripping will be adsorbed immediately.
>If you do have moisture present in the area where the ducts run, then ventilation is required. Then I would insulate for the benefit of the air conditioning. I do like the heating of the area in the winter for the reasons cited.
>the ducts are in a full basement. I figured I would do it more for noise asorption of my shop tools then heat lost. Now I am going to have to see how many resgisters are down there before I insulate or not.
I am in the Cleveland OH area so cold is sometimes a problem.
The plumbing always gets insulated in my houses just something I do.
>I recommend sealing the ducts with mastic, it will improve distribution efficiency. Sealing the cold air returns will also keep dust from being sucked into the system. The mastic works better than the silver tape for sealing ducts.
If you use something like recycled denim insulation with sheet rock over it, you'll maximize the soundproofing.
I was just in Cleveland last month for the Affordable Comfort national energy conference on energy efficiency in homes. Duct efficiency is always a hot topic.
>Mike, when we had a new house built 3 years ago I fully insulated my office because my wife has a 5'6" grand piano above me. This room is on the north side of the house and gets no direct sunlight. It is the warmest in the winter. If I were you I would insulate every wall in the house. It's cheap and you can't do it later. The heater runs will heat the wall gap so why not protect them?
The biggest benefit is sound insulation. Especially if you have a grand piano 10 feet above your head.
