OT - Cedar hedge clippings
Denis Ch�nard, Orl�ans, Ont.
>Been trimming my hedges yesterday. About 200 ft long, and up to 20 ft high at places. Some company around here takes the clippings away (they have some value to them). In amy case I've filled four large yard waste paper bags with the stuff.
Now, having been raised on a farm, I know that baling green (or wet) hay is a sure-fire way to start a fire. The forecast here calls for rain, so I'd like to put the bags inside the garage or the garden shed. I know that the stuff isn't compressed as much as hay bales, still I'm concerned that the stuff could overheat...
Am I worrying for nothing?
TIA,
DC
Re: OT - Cedar hedge clippings
Ron Hildreth, Alta, Iowa
>Denis,
You have good reason to worry. Several years ago I hired a tree service to take down a 200+ year old soft maple tree in my back yard. The contractor loaded all the wood chips into an old wooden boxed farm wagon he had brought with him, and left it parked in my yard overnight. By 4:00am the next morning we had the fire dept here as it had started to smolder. Good thing the neighbor goes to work early, as he was the one that found it. Believe me when I say it was HOT!! I've been careful of things like that since, even getting rid of my grass clippings immediately after mowing the yard by hauling to the local yard debris dump set up by our town (free!).
Why not pile them on the ground under a plastic tarp away from the house/garage, etc. Might be good insurance--tarps are cheap!
Ron in Iowa
Jesper, Denmark
Jesper, Denmark
>You worry too much. Cedar is not going to decay, so no heat build-up.
Not likely to...
Tom Dunlap in Atlanta
>...combust in a short time. I think that if you were concerned you could wet down the bags of clippings or keep the tops of the bags open.
That chip truck that was 'smoldering' was more than likely just steaming. A result of composting the fresh chips. My chip truck has done the same thing many times. The most likely combination of events is when a job is done right after a rain with lots of leaves followed by a cool night. The composting reaction starts up overnight generating heat and vapor which can look a lot like smoke if the night/morning is cool.
Years ago the fire department was called because neighbors of the storage lot where I parked my chip truck thought it was on fire. When I found out I expected to get a bill from the fire department but I never heard a word from them.
The composting heat can get uncomfortably not though. On several occasions I pulled back the outer layers of chips to feel how hot the center of the load was. Dang hot! A chip pile on the ground doesn't get as hot as inside the chip truck.
Compost piles are very unlikely to spontaneously combust because they don't have the correct fuel/air ratio. Too wet and too much air.
Tom
