Re: Getting What You Pay For.
>Once you rule out a SawStop which is in a separate class for obvious reasons, I think you need to assess what your needs in a saw are. As was mentioned, most any of the cabinet saws will, properly adjusted, produce a precise cut. The differences come out over time and use. The PM has always been a production machine whose mass and precision insure that its settings will remain constant cut-after-cut, all day or all week. That kind of quality and stability is required in a production shop, where the saw pays back more than its price in labor cost savings. While I might like to say "I have a '66", I clearly don't need one, and in my hobbyist's basement Shoebox Woodshop, the JET, at less than half the price, will do just as well for me. After all, its not the tools but what they produce that makes you a craftsman. I started out with a Crapsman C-saw that I had to measure and set the distance from the blade to the fence at both the front and rear of the blade for every cut. When I make a cut on the JET, I set the indicator on the fence and nothing more, because I know that what I set is what I get. I also know that if I were shoving stuff through that saw for 8 hours a day, I'd be checking its set up far more often than I do now.
In that context, the Griz may be all the saw you need, just be willing to spend more time keeping it tweeked and tuned. I know a local pro who makes pool tables. He burned up a pair of Uni's, and now only buys Griz saws about every 4 years when they start to give out. He calculates from the cost/benefit side that he's ahead of the game that way.
Just remember that a properly tuned saw is the primary prerequisit for safety. How much time you will need to spend keeping it that way may be directly proportional to how much you'll use it and how much you spend on it.
Too bad none of the mags does a saw comparison by setting up a cut on each machine, then repeating that cut 1,000 times, and measuring the first and last pieces for variation.
mm
