>I've been doing some shop cleaning. Today's project was the cabinet that holds all of my sanding supplies. There were 5" RO disks everywhere. Anyone have any tips or plans for some sort of storage system for these disks. My little brain is somewhat racked trying to come up with a solution. Thanks, Paul
>One of the WW magazines ran a piece on a ROS storage station. The guy made a little cabinet with a number of pull out shelves. Each shelf had a certain grit on it, so you would need one for each grit you use. There was a set of dowels that were in a pattern that matched the holes in the disks. The disks were stored grit side down with the hook and loop stuff up.
When I saw it I laughed. I thought the author was a little too anal for me. Organization is fine, but this was too much. Then I read the explanation. To install a pieces paper on his sander, he peeled off the old one and then set the sander down of over the pins. The dowels slide into the air holes, perfectly aligning the disks. Now, that made sense. No more fiddling to get the disk aligned just so.
Might work nearly as well to have some little drawers for the disks and a piece of wood with the dowels in it. You would put the disk you are about to use over the dowels and set the sander on it. Might seem a little silly, but I'm thinking that if you made one, it would only take a little while and once you had it, there would be blue sky and not a cloud in sight.
Each of my ROSanders is stored in individual shop made tool box which I designed. The tool boxes have sufficient room to store several boxes/rolls of discs of various grits. Thus, when I need to sand, I simply grab the box containing the sander I want to use, AND GO SAND. Whenever possible, I sand outdoors. I commonly have 8o, 120, and 220 grit in each of the tool boxes. My bench stock inventory of paper/discs is situated in the basement, and contains all sanding supplies in a single upright file cabinet. I try not to get hung up on transferring discs from one storage box to another, or putting all the discs over pins. I have always been able to slap a disc on a sander pad easily, and get on with it. Klingspor always reminds me of John Wayne: True Grit.
>I keep my disks & paper in hanging folders designed for filing. May be 15 or 20 sheets in each. They hang in an inexpensive plastic holder you get at staples or any business supply. It's about 5.5" deep & the legal size. Each folder has one of those clear plastic tabs with the grit size and disk or sheet marked on it. They are packed dense enough they stay flat & minimal air movement and very accesable. I keep my small bits in there too.
>All my sanding supplies get thrown in a plastic bin that slides onto a shelf. In their original containers, if possible. That bin gets dragged along whenever I need to take it anywhere for sanding. Holds sanders, blocks, parts, etc.
