Flatten a cupped board
Alan Young
Alan Young
>Ok I should know this but I don't and I over ananlyzed it...
I have a solid panel glue up that has cupped... don't ask how this happened :^(...anyway with the hope that setting it up so one side drys to relieve the bow ..what side should face up- ie towards air and sun?
Thanks
-Alan
Re: Flatten a cupped board
Tim Caley - North Little Rock
>I would think that you would want the cupped side facing down.
Gene Gauss
>I've flattened cupped panels and individual boards by lying them, concave side down, on a concrete floor for a couple of hours. Check it frequently, and when it's about flat, fasten it in to its final placement so that it is confined from cupping again as the moisture profile across the thickness again becomes uniform. I've never tried using the sun, but it ought to work somewhat the same way if you face the convex side toward the sun. Luck. Gene Gauss
Andre Mallegol
>Alan,
At times I've been able to flatten a cupped board by placing the cupped (concave) side down and putting weight on top. When this doesn't work, if the concave side is the good side I've had success by cutting a series of kerf's into the convex side to where it takes 10# to flatten it. Then it can be successfully screwed into the base.
Andre
Robin Corell in Atascadero, CA
>Truth is it really dosent matter because the wood fibers are not streatching or compressing. if you lean the pannel up so both sides get air it will equalise to where ever it decides is equalibriam. you can speed up some movement by putting the panel cup side up on a bench if it is humid out, or cup side down on a concrete slab, or possibly cup side down in the sun if you are a gambling man. but all of these my only be a temporary fix if the true equalibriam of the panel is not flat.
You know all this your just over thinking it because you don't want to make the new pannel you know is neccesary :)
Robin Corell
Convex Side Up, Allan
>Let the sun and warmth work on the cells most filled with that nasty moisture. Squeeze it out, add yeast and grain and hops to the liquid. Drink after a few days. Better a flat panel than a flat beer. :<)
George
Alan Young
Of all the answers here the only correct one is
Alan Young
>That by Robin
You know all this your just over thinking it because you don't want to make the new panel you know is necessary :)
Well I mean the MOST Correct. Indeed the panel will be remade. The current pieces are not useless, I'll rip them and re-plane them and they will be used elsewhere.
Thanks though to everyone for your help. George- Is flat beer worse than no beer?
Alan
disagree (maybe) and fundmental principals
Bill Tindal, E.TN
>1. When wood absorbs moisture it expands. So the wetter side is the larger radius (convex side). You didn't say how the panel got bowed. It might be from one side gaining moisture or the other side loosing moisture. It will flatten by adding moisture to the concave side or removing moisture from the convex side. I use a damp news paper covered by a dry newspaper sheet and lay the convex side on the paper. In minutes it will flatten. This technique is useful when the top must be flat for routing an edge, for example.
2. Because panels can become not flat one should design to constrain them to be flat in the final assembly. Table tops get fastened down, door panels are captured in a dado, etc. If the capturing strategy will pull the panel flat don't worry about flattening it before assembly. A good test is to put the panel on something flat, eg saw table top. Push on it and see how much force it takes to flatten it. This test will provide information on how much force it will take to cure the problem. On a large 3/4" panel, it will probably be very little force to flatten a 3/4" cup. In one extreme case I pulled more than an inch of twist out of a small table top and it has done fine for the following 5 years.
