Swivel frame connection
>I have been assigned the task of making a swiveling white board, similar to the one shown below. I figured I would put 1/4" or 5/16" bolts in the white board frame, thread them through some sleeves in the stand and then use star knobs to hold the white board frame to the stand.
Any other ideas about how to connect the frame to the stand and allow it to swivel? TIA.
Re: Swivel frame connection
Kneale Brownson in Northern MI
>I think someone has a hardware kit for those tilting mirrors that have a stand and the mirror in a frame that has a swivel connection to the stand with the ability to tighten it so it stays in the same place.
I've made large embroidery hoop stands that tilt using wingnuts to tighten them into a desired position. I just used a carriage bolt epoxied in place and the wing nut with some flat washers. I think the mirror kits I've seen included a sleeve for the frame. You'd probably want that so the weight of your board wouldn't wear the hole in the frame.
Curly Smith
>I'd be inclined to use a piece of steel rod inside a copper bushings at the top (I think 1/2" copper couplings just fit a 3/8" rod) and then some type of bullet catches on the bottom sides. Nothing wrong with the Star knobs but it seems like it would be rather slow to flip.
