THE WOODRAT IS BACK!
Screaming Bandsaw
Screaming Bandsaw
Screaming Bandsaw
Sandor in middletown, DE
>I have the Grizzly G0555 14" bandsaw. It has (cheap) bearing guides top and bottom.
When sawing I get pitch buildup on the sides of my blade (timerwolf 3tpi resaw) and on the rollers and the saw starts to make a horrible high pitch grinding vibrating noise. I have about a paper's (.003")thickness clearance between the blade and the side bearings. And about 1/32" clearance between the blade back and rear thrust bearings.
If I clean the pitch off, it is acceptably quiet until more pitch builds up. I've resorted to keeping a can of WD40 next to the saw and spray the blade when it gets noisy (after about 2 linear feet cutting distance of 4" thick Pressure treated SYP)This is a bandaid fix as the noise comes back quickly.
Are cool blocks better? Would higher grade bearings help? Anyone else have similar bearing guide noise experiences?
Re: Screaming Bandsaw
Ted Wong
>Try using Bandade by lenox. It's a bandsaw blade lubricant and inhibits pitch buildup. Alternately avoid cutting woods that have alot of resin in them.
>Change to a 3tpi carbide tipped blade. It'll really make the bandsaw scream, but in a good way.
Clint
Falberg saw Co
>It sounds loke your guide rollers are way too close; try .030". If that causes your blade to start drifting I would re-set the blade a little wider. If you're only re-sawing you could get by with cool blocks OK. PAM is just as good and significantly cheaper. Or you can dip a brush in laquer thinner to occasionally clean up the blade and rollers. If really want to see what a re-set can do - send me your blade and I'll re-set it for you, gratis (shipping is on you).
Replace it with a moaning bow saw
Sandor in Middletown, DE
>Thank you for the offer, but I'm going to pass. I opened the guides to have about .030" clearance and used PAM cooking spray. This helped quite a bit. Since I'm just basically resawing, the guides can be loose for this cut.
Thanks!
Sandor
Re: Replace it with a moaning bow saw
>Well I started with a Disston #8 5 1/2 Rip saw and that was pretty slow going. That was the peaceful way, but took way too long.
Then I switched to my japanese pull rip saw which was faster (even though it has more TPI) but I didn't really wan't to do outdoor garden carpentry with my nice saw.
So I broke out the Sawzall and that was just a mess. I even tried a chainsaw and have newfound respect for chainsaw carvers. So that was out.
Then I got the bandsaw set up for resawing and that worked like a champ. Each cut was about 10 seconds instead of 10 minutes with the Disston.
BTW I'm installing 500' of split rail fence and just b/c of where the posts had to go I needed to shorten 36 rails. The ends are tapered to fit into the posts so I had to make new tapers after cutting to length.
And a resaw bowsaw is on my long list of projects that I'd like to make but don't have the time... : )
Sandor
Paul Waddle
>A resaw bow saw hmmmm. Well the old timers did that cutting out boards,but your time will be better spent getting the bandsaw tuned the way you need too.Its the project that counts,not in tooling to accomplish it. I know,I've spent my life tinkering with ways instead of just doing the job and moving on.Regards.pw
