Laminate Flooring Question
>We are getting ready to put down a laminate floor. Can anyone who as done this give me an idea as to how much time it took to do this (and what size the room was)? Did you run into any unexpected problems (other than floor flatness)?
I do not want folks to tell me that I should put down real wood. That solution does not work for us.
Thanks.
Re: Laminate Flooring Question
Vapor barrier and marriage counceling
>Just finishing up about 1600 sq.ft. Took about 12 months.
Vapor barior is very important (so I'm told by flooring professionals) so we used 6 mil plastic. Also used best available felt underpadding, makes a world of difference. The plastic and underpadding is definitely more than half the work, it really is.
Ripped out all the 3.5" floor molding and quater round and repalced with 5.5" molding and quarter round. Pulled off the the all the door trim and doors (7 of them) to make it easier.
Big expanses, like my 28' x 16' rectangular room and my 24' x 14' rooms went relatively quickly. But the foyer and the stairs and the 45 degree wall made the last part a nightmare.
I made a "bammer" using angle iron and wood and used a 5lb hammer to tighten the ends. Used a long piece of scrap flooring (with the proper mating edge) to tap the long ends tight.
If you use light wood (we used light maple) go for the best quality flooring you can, as the biggest difference in flooring quality is the tolerances of the edges. It takes 0.001" (completely made up number) which is impossible to see... until you get the pices jioined, and with a light wood you see the seams. We went with the highest quality flooring and glad we did.
Do it yourself and you can afford the better materials.
Do it yourself, in a home with a young family, in the livign areas, while you aer trying to live, and it will takes months and months longer than you'd imagine. Divore mentioned, but luckily avoided. I've learned enough to write a book ;)
Happy Woodworking!
Jim Swank
>Scrap blocks of flooring to tap the boards in place, or buy the plastic tapper and metal puller in a kit. The older style pergo joints go together easier than some of the others, in my experience, but may not hold quite as well. Use the 6 mil plastic, as you've already been told, and use either an acoustic mat or buy the flooring with a thin foam layer already attached as I did. You won't like the sound if you omit the foam.
And last but least, no matter what the instructions say, tap along the length of each piece using the tapper block and a hammer as you go to make sure each seam is really tight.
I did the kitchen in one evening but spent the next two trimming in the last edges. Good luck!
ScottS
>A lot of good advice already. I put down 1300 sq. ft. of Quickstep last year. It took a couple of months to do all of it, but I live alone and there wasn't a huge hurry. Large areas go quickly. Smaller areas require lots of cuts, which chew up time. Having a helper can really speed things up! On some smaller areas, I found I spent more time walking back and forth to the saw to make cuts than I did installing the floor! I bought a Delta TwinLaser 12" miter saw and was darn glad to have it around for this project. Replacing trim and molding probably took as long as the rest of the flooring job...
I undercut door jambs using a Japanese-style pull saw. It worked well, but took a surprising amount of time. And I had a lot of doors to deal with. If I'd known at the beginning of the project that a Bosch 1640VS jamb saw was only $99, I would have purchased one and saved myself a lot of time!
I went with a combo vapor barrier plus foam padding on the advice of my salesman. Wish I hadn't. The vapor barrier needs to run up the wall a couple of inches, which is easy if you're using 6mil plastic, but difficult if it has a layer of foam padding attached. If I had to do it over again, I'd go with separate vapor barrier and foam. Perhaps a bit more work to put down, but it would make putting the trim back in place much easier.
The QuickStep I used had a click-together joint, which seemed to work very well. A metal pull bar is definitely a requirement. I had to do a bit of tapping, but not too much. I found a white rubber mallet that seemed to work pretty well for tapping on the pull bar. The black mallet I started with had a bad habit of marring the floor given half a chance. Not permanently, but cleaning up the marks took time. The edges of the flooring are fragile. If you're having a tough time getting a piece in, don't continue to hammer in the same spot over and over. You'll eventually damage the edge and the joint will never seat properly.
Prepping a room is important! The floor really does need to be very clean and flat. Not necessarily level, but flat. I had a nail embeded in my slab foundation at one doorway. There was so little of it protruding that I couldn't get a decent grip to pull it out. Figured that it wasn't much taller than the foam, so it probably wouldn't be noticed. Wrong! Every time I step on that particular board I can feel that nail. Should have pulled out the grinder and made it perfectly flat...
Think about layout and transitions from one room to the next before you start. At the edges of your room, you may have to make cuts along the length of the board to get the last piece to fit. The smaller these pieces are, the more problematic it will be to make the cuts and get the board in place. I tried both a rail-guided circular saw and a jigsaw for making these long cuts. In my older home, the rooms often weren't square which ruled out using the table saw for many of the cuts. I found the jigsaw a bit easier to use, but only because I didn't have a decent cutting setup for the circular saw. A fine-tooth blade will help to avoid chips on the surface of the laminate. If you place T-molding transitions at room boundaries, you may have more choices in how you lay the boards down, which in turn could prevent you from having to try to slide a 1-2" sliver in to finish off the edge of the room.
Finally, you'll need to figure out how big of a gap to leave around the edges of the room, so the floor can "float". My salesman confidently told me to leave a 1/4" gap... but the installation directions for my floor suggested that 3/8" was more appropriate for my install. I haven't noticed much expansion during the last 6 months, but the humidity in my area is pretty consistent. I have a buddy who installs flooring in Texas and he has some horror stories to tell about people who didn't allow the flooring to acclimate, left too little gap, and then had the entire floor start to buckle!
Larry Clinton At Frankfort (Central)., Indiana
>We ( my son, friend and I) installed one in my kitchen (12' X 25') and living room (18' X 28') also my son's living room (16' X 16'), bathroom 14' X 16') and kitchen 14' X 16'). We used the combination vapor barrier and pad in all installations. My kitchen was not the "snap lock" but was the glue joint (Formica brand). The remainder was various brands of the snap lock style. However due to my son having pets, he was afraid of an accident - so glued all his joints. My kitchen was the first floor we laid about 5 years ago. It has held up well despite several severe water spills. It is a light color (Bamboo) but the seams blended well. I pulled all trim, kitchen took two partial days as we moved the appliances to one side - installed a little over half the floor, let the glue dry overnight, moved the appliances onto the new floor and laid the rest. The living room was completed in one fairly long day. I do have the shop - so ripping the boards and cutting out registers, etc was done there. We laid all the son's kitchen and living room in one day. He was in process of remodeling so no trim was in the way. My living room is 3 years old, son's floors are about 1 1/2 years old. We are both very happy with the floors.
Kirk (KC) Constable
>Knee pads or an old pillow will make you much happier the next day(s).
jasony
>KNEE PADS! Used them on the second day. Should have used them on the first.
Use the pull bar to get each row tight (by hitting the end of each piece and then the end of the rows.
Check each row after you're done. Each seam and joint. You'll be glad you did. Checking now is better than pulling up three or four rows to fix that joint that'll bug you forever if you ignore it.
Yes, the oddly shaped pieces will take forever. Be patient. It's worth it.
I second the replies that have said to put down good underlayment. I used the thick (6mil?) "silent" underlayment. It's very nice.
The floor WILL flex very slightly when it's in. Not a big deal.
Oh yeah... the floor WILL dent, too. I learned this the hard way. It's not as durable as wood, but it's so much cheaper!
I did my 200 sq ft office in two days. There were about a dozen odd cuts that took me up to 20 minutes each. Pull the trim off if you can and use spacer blocks as per the directions. You might also find it easier to yank the door trim off and reinstall after the floor is in. Otherwise you might have some difficulty around the trim.
I'll be posting pics of my whole room remodel here, along with the included cabinetry I built. It was worth it to do the wood floor and I'm glad I did it myself. If you're like me, you'll take your time and be very picky about the joints, but it's worth it. Every time a friend walks into the room and says "you did this?!?!" I get the same good feeling as when I finish a big table or cabinet for my wife.
Oh, last piece of advice: get yourself a nice wood block. I used a 1" by 6" long piece. A scrap of 2x4 ripped in half would to thought I used some hard maple scrap. Every time you finish a row of flooring go back down the row and knock the joints tight, using the wood block as a guard to keep from damaging the tongues. This really tightens up the joints and gets them ready for the next row.
Good luck!
jason
Robin Corell in Atascadero, CA
>My brother and I installed about 400' of the glue joint type sold and home depot. and I later instaled another 100' for my parents. In my brothers app we installed over bare cncrete and used the foam padding and no additional vapor barrier. the house is 15 years old and the lamainate was installed 5 years ago and no problems . we followed the spacing recomendations except at the door jambs which if we had left 3/8" it would have shown. we used a fluch cut saw and left 1/4" gap at the jambs and 3/8" elsewhere. On my parents app I left 1/4" becaise they wanted me to re install the same trom because it was stained to match their cabinets. thwere have not been any buckling issues in either install(parents instal was over existing vinyl) My brother and I installed his flooring in two weekends, we probably could have done it in one but our knees couldn't so ot streatched out to two and he spent a third finishing up the trim. I did my parents kitchen in one weekend including the trim.
The only problems we encountered was that there is a noticable difference in the consistancy in the width of the boards. after I figured it out I started matching up the width of the ends at a but joint so the adjoining board didn't show a gap where it was tight against one and not the other. After installing a couple of courses we returned to the store to purchase the strap clamps, well worth the money. the clamps are best used with two people one on each end to make sure the clamp does not pop off and damage the edge. also small scraps of the mating tounge or grove help get a better grip with the clamps.
I was able to get the waste down to less than 5% by ripping new tounges or grooves on some of the scrap so I could use it. Don't skimp on the glue and clean it up imidiately.
Robin Corell
First, turn off the ceiling fan (yep, I didn't).
Dave Bair, Eaton Rapids, MI
Thanks guys!
>I've got some choices to make and not a lot of time. Your input is really helpful!
