Molding instilation . . .
s.mackay@worldnet.att.net
>LOML's project but . . . Rooms stripped and re-painted, molding finnished with urathane and look'n good. Think I've even become acceptable with the miter cuts ( so far so good ). Takeing some time out of the busy day I was going to try installing it. I've " thrown it up " in barracks but want this to look nice. I tried 1" panel nails but they pull out of the drywall . As I never go into HD without allready knowing what I'm after . . . what am I after ? Wanted to surprise her with my wood majic before the weekend.
Re: Molding instilation . . .
>Either I missed it or you have not told us what type of molding you are installing.
The 1" brads are failing because they are not long enough. The Drywall is probably a half inch (3/8 to 5/8" depending on where you are and what room you are in) and if the molding is half inch or more you have only nailed it to the drywall. You must penetrate the drywall (it has almost no nail holding ability) and drive the nails into the framing at least an inch. IIRC, 6 penny or 6d nails are 2" and 8d are 2 1/2". These would be useful for nailing fairly thin trim directly through drywall into framing. 4d nails could be used for nailing very thin trim directly to another piece of wood as in the thin edge of a widow facing to the jamb. 16d nails might be used for nailing through crown into the plates, right through the "middle" where the void would be. Nails are cheap, buy an assortment.
There is a lot to know about installing trim. Houses are seldom perfectly square and plumb and true. When I used to install trim as a part of earning a living, I would look at corners and decide if they were "over square" or "under square" and cheat the miters. I also found that many windows project through past the inside of the wall and would cut a slit compound miter on them to compensate. I could prattle on or hours, but since I don't know exactly what trim you are installing I'll stop.
You need an air nailer and a compressor
Ellis Walentine, Host
>You need an air nailer that will shoot 2" x 15 ga. finishing nails. We've had many discussions here about which guns are best and why. Check the archives if you want to do some homework.
I'll never hammer a nail into trim again, unless there's no other way.
Re: You need an air nailer and a compressor
Joseph Mulherin Indio, CA
>Ellis is correct in advising you to get a compressor and nailer. I got my pancake compressor and nailers at Harbor
Freight all for about $160. You can also buy various nails lengths to suit the nailgun.
Ah, ha ! . . .
>Barracks are mostly cinder block so I cheated with insert anchors. NOW I need to go into the framing ? Well, well, mystery solved ! Thank you VERY much ! Probably from her also ! He, he.
So I can blame the new gear on you guys ?
Jim Dillon
>Yes, a small air compressor and a finish nailer are the way to go for a really neat job and to have fun at the same time. Nothing like dinging a newly painted piece of trim to spoil your day. And a compressor has so many other uses around the shop, home, auto etc. Then you need a brad nailer, a stapler, a micro pinner, a ... . Well, you get the picture 8-).
Jim
15G
>Is 15G is necessary? I'm not sure if that's a bit big, unless I misunderstand the application.
Around here I've seen 15G used for interior window/door frames (3/4" stock), but I use a whole lot more of 16G used for any moldings or trimwork.
I use 16G for moldings trim, and even 18G for the thin/smaller trim and quarter rounds.
I have pulled off almost half the trim in this house and they used (20 years ago) 16G everywhere.
Happy Woodworking!
Re: 15G or 16G
Glenn Madsen near San Francisco
>With Porter Cable, the biggest difference (to me, a hobbyist) is a straight square gun, or an angled gun.
PC has a sale package right now with their loud but servicable compressor, and two or three guns. See if it meets your needs.
With my 'California house', I ended up with 2" to 2 1/2" 16 ga finish nails for large crown. And, if you're like me, buy some latex caulk while you're there, too. Maybe a 12 pack. ;-)
>I whole heartedly agree with Ellis and the others. I have several nails guns and a compressor in my shop. I am working on a rental house and wanted to install one door in a split jamb. My compressor is not portable. I tried using an air bottle. Not enough air. I saw the package with the compressor and three guns at Home Depot marked way down because the box was mangled. Bought it and was going to split it with a friend who did not have the guns. The compressor started and smoked in less than 30 seconds. Took it back. Ended up buying a tiny one gallon compressor at Harbor Freight for $60. Yep, I spent $60 to avoid driving about fifty nails by hand. (The door and some baseboard.) More than a buck a nail. Like Ellis, I don't drive them by hand anymore unless all else fails. Going back and setting them is about as bad as driving them. So now I have a new toy, and I like it.
Welcome to the slippery slope. If you buy the guns, be careful. Nail gun accidents are on the rise, because they are so economical and readily available that many "amateurs" have them. Keep your hands (and the rest of your person) back from the tip. Many of us have been shot. Take my work for it, you won't like it. OTOH, hitting yourself with the hammer is no fun either.
You may also want to invest a few bucks (less than 20) in a stud finder.
Good safety reminder Barry...
Jim Dillon
>... and I should have been using your advice when I put a brad through my thumb. In my case, the brad hit an internal staple, turned around and came out the surface right into my thumb which was way to close to the area of operation. Lesson learned the hard way. Nailers are for sure not toys and must be treated with respect. Wearing safety goggles is also a good idea. Thanks for the reminder and glad you are having fun with yours.
Jim
I've even seen....
John in New Mexico
>a 2" brad glance off a hard ring in clear douglas fir, and exit the side of the trim in a perfect ring. Fortunately my finger was not in the neighborhood at the time!
John
Re: I've even seen....
>Mine was. Went though the fingernail. From the inside. Healed in about 4 weeks. Made typing on the keyboard interesting, and caused some gentle grief from the folks at the office.
I was tired, and not thinking. That's often a cause of these types of incidents. Take a break when you need one.
Re: Good safety reminder Barry...
Larry Clinton At Frankfort (Central)., Indiana
>Also been there. While assembling the forms for the foundation of my shop, I was using a Hilti with 3 1/2 nails. Holding the forms together with one hand and nailing with the other. I hit a knot, the nail came out the side through about the outside of a finger. One of those "don't want to look" episodes. luckily if it hit the bone, it bounced off. just left an ugly gash. I did go get the clamps to replace my hand holding operation immediately after bandaging the finger!
