ADVERTISE HERE - FREE TRIAL
Saw Stop Dust Collection
Gary Tenney
>Hello Folks,
I will be recieving a SS cabinet saw near the end of June. I do not own a dust collection system yet. I have a MM16 Bandsaw that I have been successfully hooking up to my Fein III Vacuum. Looking at the manual for the SS shows something like 350 CFM required, but the Fein is only around 170 CFM I think. I would love to have the short JDS Cyclone to put under my stairs, but as everyone knows the SS is very expensive. Therefore I will have to wait for a proper DC system. Finally!! The question; can I get by using the Fein for awhile until I can install a proper system? Thanks!
Respectfully, Gary Tenney
Re: Saw Stop Dust Collection
Gary Tenney
>By the way, I don't mind sweeping down the table a bit. I am most worried about keeping the blade shroud from getting clogged with debris. Thanks!
Gary
Can't speak for the SawStop...
Ellis Walentine, Host
>...as to whether its functionality is adversely affected by dust and accumulated junk in the cabinet, but, anecdotally, I lived without dust collection on my tablesaw for about the first 10 years I was in the custom business. When it got filled up, I'd open the dust door and shovel it out.
Your bigger concern might be the airborne dust that a good DC system would filter out. Maybe a little ceiling-hung air cleaner would be the ticket until you can afford a serious dust collector.
Phil Thien
>My Ryobi BT3K has a blade shroud w/ a built in 2.5" dust port. I connect a vac to it and get great results.
The SawStop, however, has a shroud connected via a rather largish (I know it is at least 4", could be 5" or 6" for all I know) hose to a dust port at the back of the saw. Connecting the Fein to this hose will result in reduced air velocity. Basically, it will get what is thrown at it, but not much more. Places like Woodcraft and Rockler DO sell adapters to go from shop vac host to 4" machine port. You could try one.
If it doesn't work at all, you could always tempoarily disconnect the SS's internal hose from the shroud and try to figure out a way to connect the Fein hose at that point. That would probably work best.
Re: Can't speak for the SawStop...
Gary Tenney
>Thanks Ellis,
This machine has a shroud that covers the blade. The cabinet should remain fairly clear of dust, but I don't want it to build up in the shroud. I suppose with a zero clearance insert, it should require only minimal suction to empty since it is so close to the blade and the area so small, but the factory manual says something like 300 or 350 CFM for some reason.
Gary
McKay Sleight
>I have two SS here at the school and I would not chance the $80 and a new blade by not having a exhaust hooked to the back of the saw. I opening is 4". A good blade is also about $80, so a relatively cheap solution would be a mobile jet or delta exhaust system. The clearance between the aluminum stop and the blade is about 2-3 mm. Saw dust may or may not cause contact that will activate the computer.
Gary Tenney
>Thanks for the response Phil. I have been using the Fein on the MM16 bandsaw via a 2.25 - 4" coupler and it has extracted the majority of the dust just fine. I really don't see why the manul shows such a high CFM requirement for the SS. I was hoping someone that had one and was also using a decent vacuum would reply. Anyhow, the SS has broken the bank. In fact I had to pay it off over a three month period, so either way, I have to rely on the Fein for a few months anyhow. Thanks again for taking the time to answer.
Gary Tenney
Gary Tenney
>Thats a very good point! I forget how little the clearance is between blade and brake assembly. Dang! I may be eating dry bread for a month or so to afford the Cyclone. I could do that easily, but don't think the wife will appreciate the new diet! Thanks very much for pointing this out.
Gary Tenney
That shroud prob'ly won't clog
>The airflow generated by the blade should keep that shroud blown out pretty well. The CFM ratings for machines are based on the volume of air you need to evacuate in order to get all the dust out. I've seen tablesaw CFM recommendations up to 500 CFM and higher for dado and molding work, and that doesn't include the extra hundred or more you need if you have a dust port on your blade guard. That dust thaat comes over the top of the blade is some of the most obnoxious of all.
